REST API reference
Retrieve ongoing SnapMirror transfers for a relationship
Accesses the list of ongoing SnapMirror transfers for a specific relationship. This is useful to monitor and manage replication activities in your storage environment.
HTTP method and endpoint
GET /snapmirror/relationships/{relationship.uuid}/transfers
Introduced in
ONTAP 9.6
Usage notes
Retrieves the list of ongoing SnapMirror transfers for the specified relationship.
  • snapmirror show
Example
GET "/api/snapmirror/relationships/293baa53-e63d-11e8-bff1-005056a793dd/transfers"
relationship.uuid
string
path
True
Relationship UUID
checkpoint_size
integer
query
False
Filter by checkpoint_size
bytes_transferred
integer
query
False
Filter by bytes_transferred
uuid
string
query
False
Filter by uuid
relationship.restore
boolean
query
False
Filter by relationship.restore
relationship.destination.svm.uuid
string
query
False
Filter by relationship.destination.svm.uuid
relationship.destination.svm.name
string
query
False
Filter by relationship.destination.svm.name
relationship.destination.consistency_group_volumes.name
string
query
False
Filter by relationship.destination.consistency_group_volumes.name
  • Introduced in: 9.8
relationship.destination.consistency_group_volumes.uuid
string
query
False
Filter by relationship.destination.consistency_group_volumes.uuid
relationship.destination.path
string
query
False
Filter by relationship.destination.path
relationship.destination.cluster.name
string
query
False
Filter by relationship.destination.cluster.name
  • Introduced in: 9.7
relationship.destination.cluster.uuid
string
query
False
Filter by relationship.destination.cluster.uuid
snapshot
string
query
False
Filter by snapshot
state
string
query
False
Filter by state
throttle
integer
query
False
Filter by throttle
  • Introduced in: 9.9
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[snapmirror_transfer]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "bytes_transferred": 0,
      "checkpoint_size": 0,
      "relationship": {
        "destination": {
          "cluster": {
            "name": "cluster1",
          "consistency_group_volumes": [
              "name": "volume1",
          "path": "svm1:volume1",
          "svm": {
            "name": "svm1",
        "uuid": "d2d7ceea-ab52-11e8-855e-00505682a4c7"
      "snapshot": "string",
      "state": "string",
      "storage_efficiency_enabled": null,
      "throttle": 0,
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
files
Specifies a file or LUN consisting of a source_path and an optional destination_path. If not specified, the destination_path is the same as the source_path.
destination_path
string
source_path
string
cluster
_links
_links
name
string
uuid
string
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
svm
_links
_links
name
string
The name of the SVM.
uuid
string
snapmirror_endpoint
Endpoint of a SnapMirror relationship. For a GET request, the property "cluster" is populated when the endpoint is on a remote cluster. A POST request to create the destination SVM endpoint or to establish an SVM DR relationship must have the property "cluster" populated with the remote cluster details. A POST request to create the destination FlexVol volume, FlexGroup volume, and Consistency Group endpoints can optionally specify the "cluster" property when the source SVM and the destination SVM are peered. A POST request to establish a SnapMirror relationship between the source endpoint and destination endpoint and when the source SVM and the destination SVM are not peered, must specify the "cluster" property for the remote endpoint.
cluster
cluster
array[consistency_group_volumes]
Mandatory property for a Consistency Group endpoint. Specifies the list of FlexVol volumes for a Consistency Group.
path
string
ONTAP FlexVol/FlexGroup - svm1:volume1 ONTAP SVM - svm1: ONTAP Consistency Group - svm1:/cg/cg_name
  • example: svm1:volume1
  • Introduced in: 9.6
svm
svm
relationship
destination
snapmirror_endpoint
restore
boolean
Is the relationship for restore?
uuid
string
snapmirror_transfer
SnapMirror transfer information
_links
_links
bytes_transferred
integer
Bytes transferred
checkpoint_size
integer
Amount of data transferred in bytes as recorded in the restart checkpoint.
relationship
relationship
snapshot
string
Name of Snapshot copy being transferred.
state
string
Status of the transfer. Set PATCH state to "aborted" to abort the transfer. Set PATCH state to "hard_aborted" to abort the transfer and discard the restart checkpoint.
throttle
integer
Throttle, in KBs per second. This "throttle" overrides the "throttle" set on the SnapMirror relationship or SnapMirror relationship's policy. If neither of these are set, defaults to 0, which is interpreted as unlimited.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
