REST API reference
Retrieve ongoing SnapMirror transfers for a relationship
Retrieves a list of ongoing SnapMirror transfers for a specific relationship. This helps you monitor the progress and status of data replication between ONTAP systems.
HTTP method and endpoint
GET /snapmirror/relationships/{relationship.uuid}/transfers
Introduced in
ONTAP 9.6
Usage notes
Retrieves the list of ongoing SnapMirror transfers for the specified relationship.
  • snapmirror show
Example
GET "/api/snapmirror/relationships/293baa53-e63d-11e8-bff1-005056a793dd/transfers"
relationship.uuid
string
path
True
SnapMirror relationship UUID
bytes_transferred
integer
query
False
Filter by bytes_transferred
relationship.destination.consistency_group_volumes.name
string
query
False
Filter by relationship.destination.consistency_group_volumes.name
  • Introduced in: 9.8
relationship.destination.cluster.uuid
string
query
False
Filter by relationship.destination.cluster.uuid
  • Introduced in: 9.7
relationship.destination.cluster.name
string
query
False
Filter by relationship.destination.cluster.name
relationship.destination.uuid
string
query
False
Filter by relationship.destination.uuid
  • Introduced in: 9.11
relationship.destination.svm.uuid
string
query
False
Filter by relationship.destination.svm.uuid
relationship.destination.svm.name
string
query
False
Filter by relationship.destination.svm.name
relationship.destination.path
string
query
False
Filter by relationship.destination.path
relationship.restore
boolean
query
False
Filter by relationship.restore
error_info.message
string
query
False
Filter by error_info.message
  • Introduced in: 9.10
error_info.code
integer
query
False
Filter by error_info.code
end_time
string
query
False
Filter by end_time
uuid
string
query
False
Filter by uuid
state
string
query
False
Filter by state
on_demand_attrs
string
query
False
Filter by on_demand_attrs
  • Introduced in: 9.13
throttle
integer
query
False
Filter by throttle
  • Introduced in: 9.9
network_compression_ratio
string
query
False
Filter by network_compression_ratio
checkpoint_size
integer
query
False
Filter by checkpoint_size
snapshot
string
query
False
Filter by snapshot
total_duration
string
query
False
Filter by total_duration
last_updated_time
string
query
False
Filter by last_updated_time
  • Introduced in: 9.14
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[snapmirror_transfer]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "bytes_transferred": 0,
      "checkpoint_size": 0,
      "end_time": "2020-12-02 21:36:19 -0500",
      "error_info": {
        "code": 6620046,
        "message": "Transfer aborted"
      "last_updated_time": "2023-09-15 19:58:39 -0400",
      "network_compression_ratio": 61,
      "on_demand_attrs": "read_write_with_user_data_pull",
      "relationship": {
        "destination": {
          "cluster": {
            "name": "cluster1",
          "consistency_group_volumes": [
              "name": "volume1"
          "path": "svm1:volume1",
          "svm": {
            "name": "svm1",
        "uuid": "d2d7ceea-ab52-11e8-855e-00505682a4c7"
      "snapshot": "string",
      "state": "string",
      "storage_efficiency_enabled": true,
      "throttle": 0,
      "total_duration": "PT28M41S",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
error_info
Error information for the transfer.
code
integer
Error code
message
string
Error message
files
Specifies a file or LUN consisting of a source_path and an optional destination_path. If not specified, the destination_path is the same as the source_path. File restore is not supported if the source_path or destination_path contains commas in its directory or file name.
destination_path
string
source_path
string
options
cluster
_links
_links
name
string
uuid
string
name
string
The name of the volume.
svm
_links
_links
name
string
uuid
string
snapmirror_endpoint
Endpoint of a SnapMirror relationship. For a GET request, the property "cluster" is populated when the endpoint is on a remote cluster. A POST request to create the destination SVM endpoint or to establish an SVM DR relationship must have the property "cluster" populated with the remote cluster details. A POST request to create the destination FlexVol volume, FlexGroup volume, Consistency Group, ONTAP S3 bucket and NON-ONTAP object-store endpoints can optionally specify the "cluster" property when the source SVM and the destination SVM are peered. A POST request to establish a SnapMirror relationship between the source endpoint and destination endpoint and when the source SVM and the destination SVM are not peered, must specify the "cluster" property for the remote endpoint.
cluster
cluster
array[consistency_group_volumes]
Mandatory property for a Consistency Group endpoint. Specifies the list of FlexVol volumes for a Consistency Group.
path
string
ONTAP FlexVol/FlexGroup - svm1:volume1 ONTAP SVM - svm1: ONTAP Consistency Group - svm1:/cg/cg_name ONTAP S3 - svm1:/bucket/bucket1 NON-ONTAP - objstore1:/objstore
  • example: svm1:volume1
  • Introduced in: 9.6
  • x-nullable: true
svm
svm
relationship
destination
snapmirror_endpoint
restore
boolean
Is the relationship for restore?
uuid
string
Unique identifier of the SnapMirror relationship.
snapmirror_transfer
SnapMirror transfer information
_links
_links
bytes_transferred
integer
Bytes transferred
checkpoint_size
integer
Amount of data transferred in bytes as recorded in the restart checkpoint.
end_time
string
End time of the transfer.
error_info
error_info
last_updated_time
string
Last updated time of the bytes transferred in an active transfer.
string
Specifies the compression ratio achieved for the data sent over the wire with network compression enabled. This property is only valid for active transfers.
on_demand_attrs
string
Specifies whether or not an on-demand restore is being carried out. This is only supported for the transfer of restore relationships for entire volumes from the object store. A value for read_write_with_user_data_pull should be provided to start an on-demand restore. A file restore from the object store does not support this option.
relationship
relationship
snapshot
string
Name of Snapshot copy being transferred.
state
string
Status of the transfer. Set PATCH state to "aborted" to abort the transfer. Set PATCH state to "hard_aborted" to abort the transfer and discard the restart checkpoint. To find "queued" transfers refer to relationships GET API.
throttle
integer
Throttle, in KBs per second. This "throttle" overrides the "throttle" set on the SnapMirror relationship or SnapMirror relationship's policy. If neither of these are set, defaults to 0, which is interpreted as unlimited.
total_duration
string
Elapsed transfer time.
uuid
string
Unique identifier of the SnapMirror transfer.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
