Retrieves the list of ongoing snapmirror transfers for the specified relationship
example
<br/>
get "/api/snapmirror/relationships/293baa53-e63d-11e8-bff1-005056a793dd/transfers"
learn more
doc /snapmirror/relationships/{relationshipuuid}/transfers](#docs-snapmirror-snapmirror_relationships_{relationshipuuid}_transfers) <br/>
GET /snapmirror/relationships/{relationship.uuid}/transfers
Retrieves the list of ongoing SnapMirror transfers for the specified relationship.
Related ONTAP commands
snapmirror show
Example
GET "/api/snapmirror/relationships/293baa53-e63d-11e8-bff1-005056a793dd/transfers"
relationship.uuid |
string |
path |
True |
Relationship UUID |
snapshot |
string |
query |
False |
Filter by snapshot |
checkpoint_size |
integer |
query |
False |
Filter by checkpoint_size |
bytes_transferred |
integer |
query |
False |
Filter by bytes_transferred |
uuid |
string |
query |
False |
Filter by uuid |
relationship.uuid |
string |
query |
False |
Filter by relationship.uuid |
relationship.destination.path |
string |
query |
False |
Filter by relationship.destination.path |
relationship.destination.svm.name |
string |
query |
False |
Filter by relationship.destination.svm.name |
relationship.destination.svm.uuid |
string |
query |
False |
Filter by relationship.destination.svm.uuid |
relationship.restore |
boolean |
query |
False |
Filter by relationship.restore |
state |
string |
query |
False |
Filter by state |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[snapmirror_transfer] |
"next": {
"href": "/api/resourcelink"
"records": [
"bytes_transferred": 0,
"checkpoint_size": 0,
"relationship": {
"destination": {
"path": "svm1:volume1",
"svm": {
"name": "svm1",
"uuid": "d2d7ceea-ab52-11e8-855e-00505682a4c7"
"snapshot": "string",
"state": "string",
"storage_efficiency_enabled": null,
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
files
Specifies a file or LUN consisting of a source_path and an optional destination_path. If not specified, the destination_path is the same as the source_path.
destination_path |
string |
source_path |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
snapmirror_endpoint
Endpoint of a SnapMirror relationship.
path |
string |
ONTAP FlexVol/FlexGroup - svm1:volume1 ONTAP SVM - svm1:
svm |
relationship
destination |
Endpoint of a SnapMirror relationship. |
restore |
boolean |
Is the relationship for restore? |
uuid |
string |
snapmirror_transfer
Snapmirror transfer information
_links |
bytes_transferred |
integer |
Bytes transferred |
checkpoint_size |
integer |
Amount of data transferred in bytes as recorded in the restart checkpoint. |
relationship |
snapshot |
string |
Name of Snapshot copy being transferred. |
state |
string |
Status of the transfer. Set PATCH state to "aborted" to abort the transfer. Set PATCH state to "hard_aborted" to abort the transfer and discard the restart checkpoint. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
