Retrieve information for a token
Retrieves detailed information about a specific clone token, gaining insights into its configuration and status within the storage system. Use this functionality to monitor or audit clone token usage efficiently.
HTTP method and endpoint
GET /storage/file/clone/tokens
Introduced in
ONTAP 9.10
Usage notes
Retrieves information for the specified token.
Related Ontap command
volume file clone token show
Learn More
DOC /storage/file/clone]
Retrieving information on clone tokens
# The API:
/api/storage/file/clone/tokens
# The call:
curl -X GET "https://<mgmt_ip>/api/storage/file/clone/tokens" -H "accept: application/hal+json"
# The response:
"records": [
"node": {
"uuid": "97255711-a1ad-11eb-92b2-0050568eb2ca",
"name": "node1",
"href": "/api/cluster/nodes/97255711-a1ad-11eb-92b2-0050568eb2ca"
"uuid": "905c42ce-a74b-11eb-bd86-0050568ec7ae",
"reserve_size": 10240,
"expiry_time": {
"limit": "PT1H10M",
"left": "PT1H9M"
"href": "/api/storage/file/clone/tokens/97255711-a1ad-11eb-92b2-0050568eb2ca/905c42ce-a74b-11eb-bd86-0050568ec7ae"
"num_records": 1,
"href": "/api/storage/file/clone/tokens"
expiry_time.limit |
string |
query |
False |
Filter by expiry_time.limit |
expiry_time.left |
string |
query |
False |
Filter by expiry_time.left |
reserve_size |
integer |
query |
False |
Filter by reserve_size |
node.uuid |
string |
query |
False |
Filter by node.uuid |
node.name |
string |
query |
False |
Filter by node.name |
uuid |
string |
query |
False |
Filter by uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[token] |
"next": {
"href": "/api/resourcelink"
"records": [
"expiry_time": {
"left": "string",
"limit": "string"
"node": {
"name": "node1",
"reserve_size": 0,
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
self_link
self |
expiry_time
left |
string |
Specifies the time remaining before the given token expires in ISO-8601 format. |
limit |
string |
Specifies when the given token expires in ISO-8601 format. |
_links
self |
node_reference
_links |
name |
string |
uuid |
string |
token
token
_links |
expiry_time |
node |
reserve_size |
integer |
Specifies the available reserve in the file clone split load for the given token. |
uuid |
string |
Token UUID. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
