REST API reference
Retrieve information for a token
Retrieves details of a specific clone token, which helps you manage and track the status of clone operations within your storage environment.
HTTP method and endpoint
GET /storage/file/clone/tokens
Introduced in
ONTAP 9.10
Usage notes
Retrieves information for the specified token.
  • volume file clone token show
Learn More
  • [DOC /storage/file/clone]
Retrieving information on clone tokens
# The API:
/api/storage/file/clone/tokens
# The call:
curl -X GET "https://<mgmt_ip>/api/storage/file/clone/tokens" -H "accept: application/hal+json"
# The response:
"records": [
    "node": {
      "uuid": "97255711-a1ad-11eb-92b2-0050568eb2ca",
      "name": "node1",
          "href": "/api/cluster/nodes/97255711-a1ad-11eb-92b2-0050568eb2ca"
    "uuid": "905c42ce-a74b-11eb-bd86-0050568ec7ae",
    "reserve_size": 10240,
    "expiry_time": {
      "limit": "PT1H10M",
      "left": "PT1H9M"
        "href": "/api/storage/file/clone/tokens/97255711-a1ad-11eb-92b2-0050568eb2ca/905c42ce-a74b-11eb-bd86-0050568ec7ae"
"num_records": 1,
    "href": "/api/storage/file/clone/tokens"
uuid
string
query
False
Filter by uuid
node.name
string
query
False
Filter by node.name
node.uuid
string
query
False
Filter by node.uuid
expiry_time.left
string
query
False
Filter by expiry_time.left
expiry_time.limit
string
query
False
Filter by expiry_time.limit
reserve_size
integer
query
False
Filter by reserve_size
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
collection_links
num_records
integer
Number of records.
records
array[token]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "expiry_time": {
        "left": "string",
        "limit": "string"
      "node": {
        "name": "node1",
      "reserve_size": 0,
      "uuid": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
expiry_time
left
string
Specifies the time remaining before the given token expires in ISO-8601 format.
limit
string
Specifies when the given token expires in ISO-8601 format.
self
node_reference
_links
_links
name
string
uuid
string
token
token
_links
self_link
expiry_time
expiry_time
node
node_reference
reserve_size
integer
Specifies the available reserve in the file clone split load for the given token.
uuid
string
Token UUID.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
