Retrieve information for a token
Retrieves detailed information for a specified clone token within the storage file system. This helps you understand the token's configuration and status for managing file clone operations effectively.
HTTP method and endpoint
GET /storage/file/clone/tokens
Introduced in
ONTAP 9.10
Usage notes
Retrieves information for the specified token.
Related Ontap command
volume file clone token show
Learn More
DOC /storage/file/clone]
Retrieving information on clone tokens
# The API:
/api/storage/file/clone/tokens
# The call:
curl -X GET "https://<mgmt_ip>/api/storage/file/clone/tokens" -H "accept: application/hal+json"
# The response:
"records": [
"node": {
"uuid": "97255711-a1ad-11eb-92b2-0050568eb2ca",
"name": "node1",
"href": "/api/cluster/nodes/97255711-a1ad-11eb-92b2-0050568eb2ca"
"uuid": "905c42ce-a74b-11eb-bd86-0050568ec7ae",
"reserve_size": 10240,
"expiry_time": {
"limit": "PT1H10M",
"href": "/api/storage/file/clone/tokens/97255711-a1ad-11eb-92b2-0050568eb2ca/905c42ce-a74b-11eb-bd86-0050568ec7ae"
"num_records": 1,
"href": "/api/storage/file/clone/tokens"
expiry_time.limit |
string |
query |
False |
Filter by expiry_time.limit |
expiry_time.left |
string |
query |
False |
Filter by expiry_time.left |
uuid |
string |
query |
False |
Filter by uuid |
reserve_size |
integer |
query |
False |
Filter by reserve_size |
node.name |
string |
query |
False |
Filter by node.name |
node.uuid |
string |
query |
False |
Filter by node.uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[token] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"expiry_time": {
"left": "string",
"limit": "string"
"node": {
"name": "string",
"uuid": "string"
"reserve_size": 0,
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
collection_links
next |
self |
self_link
self |
expiry_time
left |
string |
Specifies the time remaining before the given token expires in ISO-8601 format. |
limit |
string |
Specifies when the given token expires in ISO-8601 format. |
node
name |
string |
Node name |
uuid |
string |
Node UUID |
token
token
_links |
expiry_time |
node |
reserve_size |
integer |
Specifies the available reserve in the file clone split load for the given token. Also note that the minimum value for reserve size is 4KB and any value specified below 4KB will be rounded off to 4KB. |
uuid |
string |
Token UUID. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
