REST API reference
Retrieve the SnapLock retention details of a file
Accesses the SnapLock retention details of a specific file to understand its retention settings, including whether it is under a Legal-Hold.
HTTP method and endpoint
GET /storage/snaplock/file/{volume.uuid}/{path}
Introduced in
ONTAP 9.7
Usage notes
Retrieves the SnapLock retention details of the specified file. An indefinite expiry time indicates the file is under a Legal-Hold.
  • volume file retention show
volume.uuid
string
path
True
Volume UUID
path
string
path
True
Path of the file in the form "/<dirpath>/<filename>"
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
expiry_time
string
Expiry time of the file in date-time format, "infinite", "indefinite", or "unspecified". An "infinite" retention time indicates that the file will be retained forever. An "unspecified" retention time indicates that the file will be retained forever; however, the retention time of the file can be changed to an absolute value. An "indefinite" retention time indicates that the file is under Legal-Hold.
file_path
string
Specifies the volume relative path of the file
svm
svm
volume
volume
      "href": "/api/resourcelink"
  "expiry_time": "2058-06-04T19:00:00Z",
  "file_path": "/dir1/file",
  "svm": {
    "name": "svm1",
  "volume": {
    "name": "volume1",
Status: Default
ONTAP Error Response codes
Error code Description
14090347
File path must be in the format "/
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
