Retrieve SnapLock retention details of a file
Accesses the SnapLock retention details of a specified file to understand its retention settings. An indefinite expiry time signals that the file is currently under a Legal-Hold.
HTTP method and endpoint
GET /storage/snaplock/file/{volume.uuid}/{path}
Introduced in
ONTAP 9.7
Usage notes
Retrieves the SnapLock retention details of the specified file. An indefinite expiry time indicates the file is under a Legal-Hold.
Related ONTAP commands
volume file retention show
volume.uuid |
string |
path |
True |
Volume UUID |
path |
string |
path |
True |
Path of the file in the form "/<dirpath>/<filename>" |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
expiry_time |
string |
Expiry time of the file in date-time format, "infinite", "indefinite", or "unspecified". An "infinite" retention time indicates that the file will be retained forever. An "unspecified" retention time indicates that the file will be retained forever; however, the retention time of the file can be changed to an absolute value. An "indefinite" retention time indicates that the file is under Legal-Hold. |
file_path |
string |
Specifies the volume relative path of the file |
is_expired |
boolean |
This indicates if the file is under active retention or if the file is past its expiry time. |
seconds_until_expiry |
integer |
Specifies the number of seconds until the expiration time of the file. |
svm |
volume |
"href": "/api/resourcelink"
"expiry_time": "2058-06-04 15:00:00 -0400",
"file_path": "/dir1/file",
"is_expired": 1,
"seconds_until_expiry": 168,
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
Status: Default
ONTAP Error Response codes
| Error code | Description |
262179 |
Unexpected argument " |
917864 |
Operation not supported |
6691623 |
User is not authorized |
13762592 |
Operation not supported on non-SnapLock volume |
14090347 |
File path must be in the format "\/<dir>\/<file path>" |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. This field cannot be specified in a POST or PATCH method. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
