REST API reference
Retrieve SnapLock retention details of a file
GET /storage/snaplock/file/{volume.uuid}/{path}
Retrieves the SnapLock retention details of the specified file. An indefinite expiry time indicates the file is under a Legal-Hold.
  • volume file retention show
volume.uuid
string
path
True
Volume UUID
path
string
path
True
Path of the file in the form "/<dirpath>/<filename>"
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
expiry_time
string
Expiry time of the file in date-time format.
file_path
string
Specifies the volume relative path of the file
svm
svm
volume
volume
      "href": "/api/resourcelink"
  "expiry_time": "2058-06-04 19:00:00 UTC",
  "file_path": "/dir1/file",
  "svm": {
    "name": "svm1",
  "volume": {
    "name": "volume1",
Status: Default
ONTAP Error Response codes
Error code Description
14090347
File path must be in the format "/
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
