Retrieve SnapLock retention details of a file
Obtains the SnapLock retention details for a specific file, which can include information such as an indefinite expiry time indicating a Legal-Hold status.
HTTP method and endpoint
GET /storage/snaplock/file/{volume.uuid}/{path}
Introduced in
ONTAP 9.7
Usage notes
Retrieves the SnapLock retention details of the specified file. An indefinite expiry time indicates the file is under a Legal-Hold.
Related ONTAP commands
volume file retention show
volume.uuid |
string |
path |
True |
Volume UUID |
path |
string |
path |
True |
Path of the file in the form "/<dirpath>/<filename>" |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
expiry_time |
string |
Expiry time of the file in date-time format, "infinite", "indefinite", or "unspecified". An "infinite" retention time indicates that the file will be retained forever. An "unspecified" retention time indicates that the file will be retained forever; however, the retention time of the file can be changed to an absolute value. An "indefinite" retention time indicates that the file is under Legal-Hold. |
file_path |
string |
Specifies the volume relative path of the file |
is_expired |
boolean |
This indicates if the file is under active retention or if the file is past its expiry time. |
seconds_until_expiry |
integer |
Specifies the number of seconds until the expiration time of the file. |
svm |
volume |
"href": "/api/resourcelink"
"expiry_time": "2058-06-04 15:00:00 -0400",
"file_path": "/dir1/file",
"is_expired": 1,
"seconds_until_expiry": 168,
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
Status: Default
ONTAP Error Response codes
| Error code |
Description |
262179 |
Unexpected argument " |
//end row //start row |
917864 //end row //start row |
Operation not supported //end row //start row |
6691623 //end row //start row |
User is not authorized //end row //start row |
13762592 //end row //start row |
Operation not supported on non-SnapLock volume //end row //start row |
14090347 //end row //start row |
File path must be in the format "/ |
917804 //end row //start row |
Path should be given in the format "/vol/ |
=== //end table [cols=3*,options=header] |
|Name |Type |Description
|error |returned_error a|
.Example error [%collapsible%closed] ==== [source,json,subs=+macros] { "error": { "arguments": [ { "code": "string", "message": "string" } ], "code": "4", "message": "entry doesn't exist", "target": "uuid" } } ==== == Definitions [.api-def-first-level] .See Definitions [%collapsible%closed] ==== [#href] [.api-collapsible-fifth-title] href [cols=3*,options=header] |
|href |string a|
[#_links] [.api-collapsible-fifth-title] _links [cols=3*,options=header] |
|self |href a|
[#svm] [.api-collapsible-fifth-title] svm SVM, applies only to SVM-scoped objects. [cols=3*,options=header] |
|_links |_links a|
|name |string a|The name of the SVM. This field cannot be specified in a PATCH method.
|uuid |string a|The unique identifier of the SVM. This field cannot be specified in a PATCH method.
[#volume] [.api-collapsible-fifth-title] volume [cols=3*,options=header] |
|_links |_links a|
|name |string a|The name of the volume. This field cannot be specified in a POST or PATCH method.
|uuid |string a|Unique identifier for the volume. This corresponds to the instance-uuid that is exposed in the CLI and ONTAPI. It does not change due to a volume move.
example: 028baa66-41bd-11e9-81d5-00a0986138f7
Introduced in: 9.6
x-nullable: true
[#error_arguments] [.api-collapsible-fifth-title] error_arguments [cols=3*,options=header] |
|code |string a|Argument code
|message |string a|Message argument
[#returned_error] [.api-collapsible-fifth-title] returned_error [cols=3*,options=header] |
|arguments |array[error_arguments] a|Message arguments
|code |string a|Error code
|message |string a|Error message
|target |string a|The target parameter that caused the error.
