Retrieve Snapshot copy policy details
Retrieves details of a specific Snapshot copy policy, which helps you understand its configuration and settings.
HTTP method and endpoint
GET /storage/snapshot-policies/{uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
snapshot policy show
Learn more
uuid |
string |
path |
True |
Snapshot copy policy UUID |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
comment |
string |
A comment associated with the Snapshot copy policy. |
copies |
array[copies] |
enabled |
boolean |
Is the Snapshot copy policy enabled? |
name |
string |
Name of the Snapshot copy policy. |
scope |
string |
Set to "svm" when the request is on a data SVM, otherwise set to "cluster". |
svm |
uuid |
string |
"href": "/api/resourcelink"
"comment": "string",
"copies": [
"prefix": "string",
"schedule": {
"name": "hourly"
"snapmirror_label": "string"
"enabled": 1,
"name": "default",
"scope": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
schedule
name |
string |
Schedule at which Snapshot copies are captured on the volume. Some common schedules already defined in the system are hourly, daily, weekly, at 15 minute intervals, and at 5 minute intervals. Snapshot copy policies with custom schedules can be referenced. |
copies
count |
integer |
The number of Snapshot copies to maintain for this schedule. |
prefix |
string |
The prefix to use while creating Snapshot copies at regular intervals. |
schedule |
snapmirror_label |
string |
Label for SnapMirror operations |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
