REST API reference
Retrieve Snapshot copy policy details
Retrieves details of a specific Snapshot copy policy to understand its configuration and settings.
HTTP method and endpoint
GET /storage/snapshot-policies/{uuid}
Introduced in
ONTAP 9.6
  • snapshot policy show
uuid
string
path
True
Snapshot copy policy UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
comment
string
A comment associated with the Snapshot copy policy.
copies
array[copies]
enabled
boolean
Is the Snapshot copy policy enabled?
name
string
Name of the Snapshot copy policy.
scope
string
Set to "svm" when the request is on a data SVM, otherwise set to "cluster".
svm
svm
uuid
string
      "href": "/api/resourcelink"
  "comment": "string",
  "copies": [
      "prefix": "string",
      "retention_period": "string",
      "schedule": {
        "name": "weekly",
      "snapmirror_label": "string"
  "enabled": 1,
  "name": "default",
  "scope": "string",
  "svm": {
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
schedule
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
copies
count
integer
The number of Snapshot copies to maintain for this schedule.
prefix
string
The prefix to use while creating Snapshot copies at regular intervals.
retention_period
string
The retention period of Snapshot copies for this schedule. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A period specified for years, months, and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PTH" and "PTM" respectively. The period string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported.
schedule
schedule
snapmirror_label
string
Label for SnapMirror operations
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
