REST API reference
Retrieve snapshot policy details
Accesses detailed information about a specific snapshot policy, helping you understand its configuration and settings for effective management.
HTTP method and endpoint
GET /storage/snapshot-policies/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Retrieves details of a specific snapshot policy.
  • snapshot policy show
uuid
string
path
True
Snapshot policy UUID
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
comment
string
A comment associated with the snapshot policy.
copies
array[copies]
enabled
boolean
Is the snapshot policy enabled?
name
string
Name of the snapshot policy.
scope
string
Set to "svm" when the request is on a data SVM, otherwise set to "cluster".
svm
svm
uuid
string
      "href": "/api/resourcelink"
  "comment": "string",
  "copies": [
      "prefix": "string",
      "retention_period": "string",
      "schedule": {
        "name": "weekly",
      "snapmirror_label": "string"
  "enabled": 1,
  "name": "default",
  "scope": "string",
  "svm": {
    "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
schedule
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
copies
count
integer
The number of snapshots to maintain for this schedule.
prefix
string
The prefix to use while creating snapshots at regular intervals.
retention_period
string
The retention period of snapshots for this schedule. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A period specified for years, months, and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PTH" and "PTM" respectively. The period string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported.
schedule
schedule
snapmirror_label
string
Label for SnapMirror operations
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
