Retrieve Snapshot copy policies
Retrieves a collection of Snapshot copy policies to review existing policies for managing Snapshot copies in your storage environment.
HTTP method and endpoint
GET /storage/snapshot-policies
Introduced in
ONTAP 9.6
Related ONTAP commands
snapshot policy show
Learn more
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
scope |
string |
query |
False |
Filter by scope |
enabled |
boolean |
query |
False |
Filter by enabled |
name |
string |
query |
False |
Filter by name |
comment |
string |
query |
False |
Filter by comment |
uuid |
string |
query |
False |
Filter by uuid |
copies.prefix |
string |
query |
False |
Filter by copies.prefix |
copies.count |
integer |
query |
False |
Filter by copies.count |
copies.snapmirror_label |
string |
query |
False |
Filter by copies.snapmirror_label |
copies.schedule.name |
string |
query |
False |
Filter by copies.schedule.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[snapshot_policy] |
"next": {
"href": "/api/resourcelink"
"records": [
"comment": "string",
"copies": [
"prefix": "string",
"schedule": {
"name": "hourly"
"snapmirror_label": "string"
"enabled": 1,
"name": "default",
"scope": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
schedule
name |
string |
Schedule at which Snapshot copies are captured on the volume. Some common schedules already defined in the system are hourly, daily, weekly, at 15 minute intervals, and at 5 minute intervals. Snapshot copy policies with custom schedules can be referenced. |
copies
count |
integer |
The number of Snapshot copies to maintain for this schedule. |
prefix |
string |
The prefix to use while creating Snapshot copies at regular intervals. |
schedule |
snapmirror_label |
string |
Label for SnapMirror operations |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
snapshot_policy
The Snapshot copy policy object is associated with a read-write volume used to create and delete Snapshot copies at regular intervals.
_links |
comment |
string |
A comment associated with the Snapshot copy policy. |
copies |
array[copies] |
enabled |
boolean |
Is the Snapshot copy policy enabled? |
name |
string |
Name of the Snapshot copy policy. |
scope |
string |
Set to "svm" when the request is on a data SVM, otherwise set to "cluster". |
svm |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
