REST API reference
Retrieve snapshot policies
Retrieves snapshot policies to view and manage the collection of policies that govern snapshot operations. Use this endpoint to ensure your snapshot policies align with your data protection strategy.
HTTP method and endpoint
GET /storage/snapshot-policies
Introduced in
ONTAP 9.6
Usage notes
Retrieves a collection of snapshot policies.
  • snapshot policy show
enabled
boolean
query
False
Filter by enabled
scope
string
query
False
Filter by scope
uuid
string
query
False
Filter by uuid
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
name
string
query
False
Filter by name
comment
string
query
False
Filter by comment
copies.retention_period
string
query
False
Filter by copies.retention_period
  • Introduced in: 9.12
copies.schedule.uuid
string
query
False
Filter by copies.schedule.uuid
  • Introduced in: 9.14
copies.schedule.name
string
query
False
Filter by copies.schedule.name
copies.snapmirror_label
string
query
False
Filter by copies.snapmirror_label
copies.count
integer
query
False
Filter by copies.count
copies.prefix
string
query
False
Filter by copies.prefix
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[snapshot_policy]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "comment": "string",
      "copies": [
          "prefix": "string",
          "retention_period": "string",
          "schedule": {
            "name": "weekly",
          "snapmirror_label": "string"
      "enabled": 1,
      "name": "default",
      "scope": "string",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
schedule
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
copies
count
integer
The number of snapshots to maintain for this schedule.
prefix
string
The prefix to use while creating snapshots at regular intervals.
retention_period
string
The retention period of snapshots for this schedule. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A period specified for years, months, and days is represented in the ISO-8601 format as "PY", "PM", "PD" respectively, for example "P10Y" represents a duration of 10 years. A duration in hours and minutes is represented by "PTH" and "PTM" respectively. The period string must contain only a single time element that is, either years, months, days, hours, or minutes. A duration which combines different periods is not supported, for example "P1Y10M" is not supported.
schedule
schedule
snapmirror_label
string
Label for SnapMirror operations
svm
_links
_links
name
string
uuid
string
snapshot_policy
The snapshot policy object is associated with a read-write volume used to create and delete snapshots at regular intervals.
_links
_links
comment
string
A comment associated with the snapshot policy.
copies
array[copies]
enabled
boolean
Is the snapshot policy enabled?
name
string
Name of the snapshot policy.
scope
string
Set to "svm" when the request is on a data SVM, otherwise set to "cluster".
svm
svm
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
