Retrieve Snapshot copy policies
Retrieves a collection of Snapshot copy policies to manage how Snapshot copies are scheduled and retained. This helps you automate data protection and recovery processes within your storage environment.
HTTP method and endpoint
GET /storage/snapshot-policies
Introduced in
ONTAP 9.6
Related ONTAP commands
snapshot policy show
Learn more
uuid |
string |
query |
False |
Filter by uuid |
name |
string |
query |
False |
Filter by name |
scope |
string |
query |
False |
Filter by scope |
comment |
string |
query |
False |
Filter by comment |
copies.retention_period |
string |
query |
False |
Filter by copies.retention_period
copies.snapmirror_label |
string |
query |
False |
Filter by copies.snapmirror_label |
copies.schedule.name |
string |
query |
False |
Filter by copies.schedule.name |
copies.schedule.uuid |
string |
query |
False |
Filter by copies.schedule.uuid
copies.count |
integer |
query |
False |
Filter by copies.count |
copies.prefix |
string |
query |
False |
Filter by copies.prefix |
enabled |
boolean |
query |
False |
Filter by enabled |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[snapshot_policy] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"comment": "string",
"copies": [
"prefix": "string",
"retention_period": "string",
"schedule": {
"name": "weekly",
"snapmirror_label": "string"
"enabled": 1,
"name": "default",
"scope": "string",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
schedule
_links |
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
copies
count |
integer |
The number of Snapshot copies to maintain for this schedule. |
prefix |
string |
The prefix to use while creating Snapshot copies at regular intervals. |
retention_period |
string |
The retention period of Snapshot copies for this schedule. The retention period value represents a duration and must be specified in the ISO-8601 duration format. The retention period can be in years, months, days, hours, and minutes. A period specified for years, months, and days is represented in the ISO-8601 format as "P |
schedule |
snapmirror_label |
string |
Label for SnapMirror operations |
svm
_links |
name |
string |
uuid |
string |
snapshot_policy
The Snapshot copy policy object is associated with a read-write volume used to create and delete Snapshot copies at regular intervals.
_links |
comment |
string |
A comment associated with the Snapshot copy policy. |
copies |
array[copies] |
enabled |
boolean |
Is the Snapshot copy policy enabled? |
name |
string |
Name of the Snapshot copy policy. |
scope |
string |
Set to "svm" when the request is on a data SVM, otherwise set to "cluster". |
svm |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
