REST API reference
Retrieve volume Snapshot copies
Retrieves a collection of volume Snapshot copies to evaluate the state and configuration of your data at specific points in time. This can be useful for backup and recovery operations or to manage storage efficiency.
HTTP method and endpoint
GET /storage/volumes/{volume.uuid}/snapshots
Introduced in
ONTAP 9.6
Expensive properties
There is an added cost to retrieving the amount of reclaimable space for Snapshot copies, as the calculation is done on demand based on the list of Snapshot copies provided.
  • reclaimable_space
  • snapshot show
  • snapshot compute-reclaimable
volume.uuid
string
path
True
Volume
size
integer
query
False
Filter by size
  • Introduced in: 9.9
expiry_time
string
query
False
Filter by expiry_time
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
create_time
string
query
False
Filter by create_time
comment
string
query
False
Filter by comment
snaplock_expiry_time
string
query
False
Filter by snaplock_expiry_time
name
string
query
False
Filter by name
state
string
query
False
Filter by state
version_uuid
string
query
False
Filter by version_uuid
  • Introduced in: 9.11
volume.name
string
query
False
Filter by volume.name
provenance_volume.uuid
string
query
False
Filter by provenance_volume.uuid
uuid
string
query
False
Filter by uuid
owners
string
query
False
Filter by owners
  • Introduced in: 9.7
snapmirror_label
string
query
False
Filter by snapmirror_label
  • Introduced in: 9.8
reclaimable_space
integer
query
False
Filter by reclaimable_space
  • Introduced in: 9.10
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
reclaimable_space
integer
Space reclaimed when the Snapshot copy is deleted, in bytes.
records
array[snapshot]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "comment": "string",
      "create_time": "2019-02-04T19:00:00Z",
      "expiry_time": "2019-02-04T19:00:00Z",
      "name": "this_snapshot",
      "owners": [
        "string"
      "provenance_volume": {
        "uuid": "4cd8a442-86d1-11e0-ae1c-125648563413"
      "size": 122880,
      "snaplock_expiry_time": "2019-02-04T19:00:00Z",
      "snapmirror_label": "string",
      "state": "string",
      "svm": {
        "name": "svm1",
      "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
      "version_uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
      "volume": {
        "name": "volume1",
Status: Default
ONTAP Error Response Code
Error Code Description
918235
The specified volume is invalid.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
provenance_volume
uuid
string
UUID for the volume that is used to identify the source volume in a mirroring relationship. When the mirroring relationship is broken, a volume's Instance UUID and Provenance UUID are made identical. An unmirrored volume's Provenance UUID is the same as its Instance UUID. This field is valid for flexible volumes only.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
snapshot
The Snapshot copy object represents a point in time Snapshot copy of a volume.
_links
_links
comment
string
A comment associated with the Snapshot copy. This is an optional attribute for POST or PATCH.
create_time
string
Creation time of the Snapshot copy. It is the volume access time when the Snapshot copy was created.
expiry_time
string
The expiry time for the Snapshot copy. This is an optional attribute for POST or PATCH. Snapshot copies with an expiry time set are not allowed to be deleted until the retention time is reached.
name
string
Snapshot copy. Valid in POST or PATCH.
owners
array[string]
provenance_volume
provenance_volume
reclaimable_space
integer
size
integer
Size of the active file system at the time the Snapshot copy is captured. The actual size of the Snapshot copy also includes those blocks trapped by other Snapshot copies. On a Snapshot copy deletion, the "size" amount of blocks is the maximum number of blocks available. On a Snapshot copy restore, the "afs-used size" value will match the Snapshot copy "size" value.
string
SnapLock expiry time for the Snapshot copy, if the Snapshot copy is taken on a SnapLock volume. A Snapshot copy is not allowed to be deleted or renamed until the SnapLock ComplianceClock time goes beyond this retention time.
snapmirror_label
string
Label for SnapMirror operations
state
string
State of the Snapshot copy. There are cases where some Snapshot copies are not complete. In the "partial" state, the Snapshot copy is consistent but exists only on the subset of the constituents that existed prior to the FlexGroup's expansion. Partial Snapshot copies cannot be used for a Snapshot copy restore operation. A Snapshot copy is in an "invalid" state when it is present in some FlexGroup constituents but not in others. At all other times, a Snapshot copy is valid.
svm
svm
uuid
string
The UUID of the Snapshot copy in the volume that uniquely identifies the Snapshot copy in that volume.
version_uuid
string
The 128 bit identifier that uniquely identifies a snapshot and its logical data layout.
volume
volume
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
