REST API reference
Retrieve volume snapshots
GET /storage/volumes/{volume.uuid}/snapshots
Introduced In: 9.6
Retrieves a collection of volume snapshots.
Expensive properties
There is an added computational cost to retrieving the amount of reclaimable space for snapshots, as the calculation is done on demand based on the list of snapshots provided.
  • reclaimable_space
  • delta
  • snapshot show
  • snapshot compute-reclaimable
  • snapshot show-delta
volume.uuid
string
path
True
Volume
version_uuid
string
query
False
Filter by version_uuid
  • Introduced in: 9.11
comment
string
query
False
Filter by comment
owners
string
query
False
Filter by owners
  • Introduced in: 9.7
volume.name
string
query
False
Filter by volume.name
uuid
string
query
False
Filter by uuid
size
integer
query
False
Filter by size
  • Introduced in: 9.9
name
string
query
False
Filter by name
state
string
query
False
Filter by state
dedup_savings
integer
query
False
Filter by dedup_savings
  • Introduced in: 9.17
snapmirror_label
string
query
False
Filter by snapmirror_label
  • Introduced in: 9.8
delta.size_consumed
integer
query
False
Filter by delta.size_consumed
  • Introduced in: 9.12
delta.time_elapsed
string
query
False
Filter by delta.time_elapsed
reclaimable_space
integer
query
False
Filter by reclaimable_space
  • Introduced in: 9.10
create_time
string
query
False
Filter by create_time
expiry_time
string
query
False
Filter by expiry_time
compress_savings
integer
query
False
Filter by compress_savings
vbn0_savings
integer
query
False
Filter by vbn0_savings
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
provenance_volume.uuid
string
query
False
Filter by provenance_volume.uuid
logical_size
integer
query
False
Filter by logical_size
snaplock_expiry_time
string
query
False
Filter by snaplock_expiry_time
snaplock.expiry_time
string
query
False
Filter by snaplock.expiry_time
  • Introduced in: 9.15
snaplock.time_until_expiry
string
query
False
Filter by snaplock.time_until_expiry
snaplock.expired
boolean
query
False
Filter by snaplock.expired
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
delta
snapshot_delta
Reports the amount of space consumed between two WAFL file systems, in bytes. The two WAFL file systems should be specified in a comma-separated format using the "name" parameter. To determine the space consumed between a snapshot and the Active File System, only the snapshot name needs to be mentioned.
num_records
integer
Number of records
reclaimable_space
integer
Space reclaimed when the snapshot is deleted, in bytes.
records
array[snapshot]
    "next": {
      "href": "/api/resourcelink"
  "delta": {
    "size_consumed": 0,
    "time_elapsed": "string"
  "num_records": 1,
  "records": [
      "comment": "string",
      "compress_savings": 1131223,
      "create_time": "2019-02-04 19:00:00 +0000",
      "dedup_savings": 1131223,
      "delta": {
        "size_consumed": 0,
      "expiry_time": "2019-02-04 19:00:00 +0000",
      "logical_size": 1228800,
      "name": "this_snapshot",
      "owners": [
        "string"
      "provenance_volume": {
        "uuid": "4cd8a442-86d1-11e0-ae1c-125648563413"
      "size": "122880",
      "snaplock": {
        "expired": 1,
        "time_until_expiry": "PT3H27M45S"
      "snaplock_expiry_time": "2019-02-04 19:00:00 +0000",
      "snapmirror_label": "string",
      "state": "string",
      "svm": {
        "name": "svm1",
      "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
      "vbn0_savings": 1131223,
      "version_uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
      "volume": {
        "name": "volume1",
Status: Default
ONTAP Error Response Code
Error Code Description
918235
The specified volume is invalid.
9437613
The operation is not supported on FlexCache Volumes.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
snapshot_delta
_links
_links
size_consumed
integer
Indicates the space that has changed between two specified WAFL file systems, in bytes.
time_elapsed
string
Time elapsed between two specified WAFL file systems.
provenance_volume
uuid
string
UUID for the volume that is used to identify the source volume in a mirroring relationship. When the mirroring relationship is broken, a volume's Instance UUID and Provenance UUID are made identical. An unmirrored volume's Provenance UUID is the same as its Instance UUID. This field is valid for flexible volumes only.
snaplock
expired
boolean
Indicates whether a SnapLock snapshot has expired.
expiry_time
string
SnapLock expiry time for the snapshot, if the snapshot is taken on a SnapLock volume. A snapshot is not allowed to be deleted or renamed until the SnapLock ComplianceClock time goes beyond this retention time. This option can be set during snapshot POST and snapshot PATCH on snapshot locking enabled volumes. It can also be used to extend the expiry time of a locked snapshot on a SnapLock for SnapVault destination consistency-group.
time_until_expiry
string
Indicates the remaining SnapLock expiry time of a locked snapshot, in seconds. This field is set only when the remaining time interval is less than 136 years.
svm
_links
_links
name
string
uuid
string
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
snapshot
The snapshot object represents a point in time snapshot of a volume.
_links
_links
comment
string
A comment associated with the snapshot. This is an optional attribute for POST or PATCH.
compress_savings
integer
Savings due to compression at the time the snapshot was taken in bytes.
create_time
string
Creation time of the snapshot. It is the volume access time when the snapshot was created.
dedup_savings
integer
Savings due to dedup at the time the snapshot was taken in bytes.
delta
snapshot_delta
expiry_time
string
The expiry time for the snapshot. This is an optional attribute for POST or PATCH. Snapshots with an expiry time set are not allowed to be deleted until the retention time is reached.
logical_size
integer
Size of the logical used file system at the time the snapshot is captured.
name
string
Snapshot. Valid in POST or PATCH.
owners
array[string]
provenance_volume
provenance_volume
reclaimable_space
integer
size
integer
Size of the active file system at the time the snapshot is captured. The actual size of the snapshot also includes those blocks trapped by other snapshots. On a snapshot deletion, the "size" amount of blocks is the maximum number of blocks available. On a snapshot restore, the "afs-used size" value will match the snapshot "size" value.
snaplock
snaplock
string
SnapLock expiry time for the snapshot, if the snapshot is taken on a SnapLock volume. A snapshot is not allowed to be deleted or renamed until the SnapLock ComplianceClock time goes beyond this retention time. This option can be set during snapshot POST and snapshot PATCH on snapshot locking enabled volumes. This field will no longer be supported in a future release. Use snaplock.expiry_time instead.
snapmirror_label
string
Label for SnapMirror operations
state
string
State of the FlexGroup volume snapshot. In the "pre_conversion" state, the snapshot was created before converting the FlexVol to a FlexGroup volume. A recently created snapshot can be in the "unknown" state while the system is calculating the state. In the "partial" state, the snapshot is consistent but exists only on the subset of the constituents that existed prior to the FlexGroup's expansion. Partial snapshots cannot be used for a snapshot restore operation. A snapshot is in an "invalid" state when it is present in some FlexGroup constituents but not in others. At all other times, a snapshot is valid.
svm
svm
uuid
string
The UUID of the snapshot in the volume that uniquely identifies the snapshot in that volume.
vbn0_savings
integer
Savings due vbn0 at the time the snapshot was taken in bytes.
version_uuid
string
The 128 bit identifier that uniquely identifies a snapshot and its logical data layout.
volume
volume
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
