Retrieve volume Snapshot copies
GET /storage/volumes/{volume.uuid}/snapshots
Introduced In: 9.6
Retrieves a collection of volume Snapshot copies.
Expensive properties
There is an added computational cost to retrieving the amount of reclaimable space for Snapshot copies, as the calculation is done on demand based on the list of Snapshot copies provided.
reclaimable_space -
delta
Related ONTAP commands
snapshot show -
snapshot compute-reclaimable -
snapshot show-delta
Learn more
volume.uuid |
string |
path |
True |
Volume |
reclaimable_space |
integer |
query |
False |
Filter by reclaimable_space
provenance_volume.uuid |
string |
query |
False |
Filter by provenance_volume.uuid
volume.name |
string |
query |
False |
Filter by volume.name |
uuid |
string |
query |
False |
Filter by uuid |
size |
integer |
query |
False |
Filter by size
comment |
string |
query |
False |
Filter by comment |
name |
string |
query |
False |
Filter by name |
version_uuid |
string |
query |
False |
Filter by version_uuid
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
snapmirror_label |
string |
query |
False |
Filter by snapmirror_label
snaplock.expired |
boolean |
query |
False |
Filter by snaplock.expired
snaplock.expiry_time |
string |
query |
False |
Filter by snaplock.expiry_time
snaplock.time_until_expiry |
string |
query |
False |
Filter by snaplock.time_until_expiry
delta.size_consumed |
integer |
query |
False |
Filter by delta.size_consumed
delta.time_elapsed |
string |
query |
False |
Filter by delta.time_elapsed
owners |
string |
query |
False |
Filter by owners
state |
string |
query |
False |
Filter by state |
create_time |
string |
query |
False |
Filter by create_time |
snaplock_expiry_time |
string |
query |
False |
Filter by snaplock_expiry_time |
logical_size |
integer |
query |
False |
Filter by logical_size
expiry_time |
string |
query |
False |
Filter by expiry_time |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
delta |
Reports the amount of space consumed between two WAFL file systems, in bytes. The two WAFL file systems should be specified in a comma-separated format using the "name" parameter. To determine the space consumed between a Snapshot copy and the Active File System, only the Snapshot copy name needs to be mentioned. |
num_records |
integer |
Number of records |
reclaimable_space |
integer |
Space reclaimed when the Snapshot copy is deleted, in bytes. |
records |
array[snapshot] |
"next": {
"href": "/api/resourcelink"
"delta": {
"size_consumed": 0,
"time_elapsed": "string"
"num_records": 1,
"records": [
"comment": "string",
"create_time": "2019-02-04 19:00:00 +0000",
"delta": {
"size_consumed": 0,
"expiry_time": "2019-02-04 19:00:00 +0000",
"logical_size": 1228800,
"name": "this_snapshot",
"owners": [
"string"
"provenance_volume": {
"uuid": "4cd8a442-86d1-11e0-ae1c-125648563413"
"size": "122880",
"snaplock": {
"expired": 1,
"time_until_expiry": "PT3H27M45S"
"snaplock_expiry_time": "2019-02-04 19:00:00 +0000",
"snapmirror_label": "string",
"state": "string",
"svm": {
"name": "svm1",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"version_uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"volume": {
"name": "volume1",
Status: Default
ONTAP Error Response Code
| Error Code | Description |
918235 |
The specified volume is invalid. |
9437613 |
The operation is not supported on FlexCache Volumes. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
snapshot_delta
_links |
size_consumed |
integer |
Indicates the space that has changed between two specified WAFL file systems, in bytes. |
time_elapsed |
string |
Time elapsed between two specified WAFL file systems. |
provenance_volume
uuid |
string |
UUID for the volume that is used to identify the source volume in a mirroring relationship. When the mirroring relationship is broken, a volume's Instance UUID and Provenance UUID are made identical. An unmirrored volume's Provenance UUID is the same as its Instance UUID. This field is valid for flexible volumes only. |
snaplock
expired |
boolean |
Indicates whether a SnapLock Snapshot copy has expired. |
expiry_time |
string |
SnapLock expiry time for the Snapshot copy, if the Snapshot copy is taken on a SnapLock volume. A Snapshot copy is not allowed to be deleted or renamed until the SnapLock ComplianceClock time goes beyond this retention time. This option can be set during Snapshot copy POST and Snapshot copy PATCH on Snapshot copy locking enabled volumes. |
time_until_expiry |
string |
Indicates the remaining SnapLock expiry time of a locked Snapshot copy, in seconds. This field is set only when the remaining time interval is less than 136 years. |
svm
_links |
name |
string |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. This field cannot be specified in a POST or PATCH method. |
uuid |
string |
snapshot
The Snapshot copy object represents a point in time Snapshot copy of a volume.
_links |
comment |
string |
A comment associated with the Snapshot copy. This is an optional attribute for POST or PATCH. |
create_time |
string |
Creation time of the Snapshot copy. It is the volume access time when the Snapshot copy was created. |
delta |
expiry_time |
string |
The expiry time for the Snapshot copy. This is an optional attribute for POST or PATCH. Snapshot copies with an expiry time set are not allowed to be deleted until the retention time is reached. |
logical_size |
integer |
Size of the logical used file system at the time the Snapshot copy is captured. |
name |
string |
Snapshot copy. Valid in POST or PATCH. |
owners |
array[string] |
provenance_volume |
reclaimable_space |
integer |
size |
integer |
Size of the active file system at the time the Snapshot copy is captured. The actual size of the Snapshot copy also includes those blocks trapped by other Snapshot copies. On a Snapshot copy deletion, the "size" amount of blocks is the maximum number of blocks available. On a Snapshot copy restore, the "afs-used size" value will match the Snapshot copy "size" value. |
snaplock |
string |
SnapLock expiry time for the Snapshot copy, if the Snapshot copy is taken on a SnapLock volume. A Snapshot copy is not allowed to be deleted or renamed until the SnapLock ComplianceClock time goes beyond this retention time. This option can be set during Snapshot copy POST and Snapshot copy PATCH on Snapshot copy locking enabled volumes. This field will no longer be supported in a future release. Use snaplock.expiry_time instead. |
snapmirror_label |
string |
Label for SnapMirror operations |
state |
string |
State of the FlexGroup volume Snapshot copy. In the "pre_conversion" state, the Snapshot copy was created before converting the FlexVol to a FlexGroup volume. A recently created Snapshot copy can be in the "unknown" state while the system is calculating the state. In the "partial" state, the Snapshot copy is consistent but exists only on the subset of the constituents that existed prior to the FlexGroup's expansion. Partial Snapshot copies cannot be used for a Snapshot copy restore operation. A Snapshot copy is in an "invalid" state when it is present in some FlexGroup constituents but not in others. At all other times, a Snapshot copy is valid. |
svm |
uuid |
string |
The UUID of the Snapshot copy in the volume that uniquely identifies the Snapshot copy in that volume. |
version_uuid |
string |
The 128 bit identifier that uniquely identifies a snapshot and its logical data layout. |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
