REST API reference
List users with the most I/O activity
Retrieves a list of users who have the highest I/O activity, helping you identify and analyze usage patterns in your environment.
HTTP method and endpoint
GET /svm/svms/{svm.uuid}/top-metrics/users
Introduced in
ONTAP 9.11
Usage notes
Retrieves a list of users with the most IO activity.
svm.uuid
string
path
True
SVM UUID
top_metric
string
query
False
IO activity type
  • Default value: 1
  • enum: ["iops.read", "iops.write", "throughput.read", "throughput.write"]
svm.name
string
query
False
Filter by svm.name
user_id
string
query
False
Filter by user_id
iops.write
integer
query
False
Filter by iops.write
iops.read
integer
query
False
Filter by iops.read
iops.error.lower_bound
integer
query
False
Filter by iops.error.lower_bound
iops.error.upper_bound
integer
query
False
Filter by iops.error.upper_bound
user_name
string
query
False
Filter by user_name
throughput.error.lower_bound
integer
query
False
Filter by throughput.error.lower_bound
throughput.error.upper_bound
integer
query
False
Filter by throughput.error.upper_bound
throughput.write
integer
query
False
Filter by throughput.write
throughput.read
integer
query
False
Filter by throughput.read
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
excluded_volumes
array[top_metrics_svm_user_excluded_volume]
List of volumes that are not included in the SVM activity tracking REST API.
notice
notice
Optional field that indicates why no records are returned by the SVM activity tracking REST API.
num_records
integer
Number of records.
records
array[top_metrics_svm_user]
    "next": {
      "href": "/api/resourcelink"
  "excluded_volumes": [
      "reason": {
        "code": "111411",
        "message": "The volume is offline."
      "volume": {
        "name": "volume1",
  "notice": {
    "code": "111411207",
  "records": [
      "iops": {
        "error": {
          "lower_bound": 34,
          "upper_bound": 54
        "read": 4,
        "write": 8
      "svm": {
        "name": "svm1",
      "throughput": {
        "error": {
          "lower_bound": 34,
          "upper_bound": 54
        "read": 10,
        "write": 7
      "user_id": "S-1-5-21-256008430-3394229847-3930036330-1001",
      "user_name": "James"
Status: Default
ONTAP Error Response Codes
Error Code Description
124519405
The activity tracking report for SVM svm.name returned zero records. Check whether the volumes belonging to the SVM have read/write traffic. Refer to the REST API documentation for more information on why there might be no records.
124519406
Failed to get the activity tracking report for SVM svm.name. Reason:.
124519407
SVM wildcard queries are not supported for activity tracking reports.
124519408
Activity tracking is not supported on SVM svm.name, because it is configured as a destination for SVM DR.
124519409
Activity tracking is not supported on SVM svm.name, because it is configured as a destination of a MetroCluster SVM relationship and the SVM admin state is stopped.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
reason
code
string
Warning code indicating why the volume is not included in the SVM activity tracking REST API.
message
string
Details why the volume is not included in the SVM activity tracking REST API.
self
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
List of volumes and their details as to why they are not included in the SVM activity tracking REST API.
reason
reason
volume
volume
notice
code
string
Warning code indicating why no records are returned.
message
string
Details why no records are returned.
top_metric_value_error_bounds
lower_bound
integer
Lower bound of the nominal value of a metric.
upper_bound
integer
Upper bound of the nominal value of a metric.
iops
error
read
integer
Average number of read operations per second.
write
integer
Average number of write operations per second.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
throughput
error
read
integer
Average number of read bytes received per second.
write
integer
Average number of write bytes received per second.
Aggregated information about a user's IO activity at a SVM scope.
iops
iops
svm
svm
throughput
throughput
user_id
string
User ID of the user.
user_name
string
Name of the user.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
