List users with the most I/O activity
Retrieves a list of users who have the most input/output activity, helping you identify active users in the system.
HTTP method and endpoint
GET /svm/svms/{svm.uuid}/top-metrics/users
Introduced in
ONTAP 9.11
Usage notes
Retrieves a list of users with the most I/O activity.
svm.uuid |
string |
path |
True |
SVM UUID |
top_metric |
string |
query |
False |
I/O activity type
total_throughput.read |
integer |
query |
False |
Filter by total_throughput.read
total_throughput.error.lower_bound |
integer |
query |
False |
Filter by total_throughput.error.lower_bound
total_throughput.error.upper_bound |
integer |
query |
False |
Filter by total_throughput.error.upper_bound
total_throughput.write |
integer |
query |
False |
Filter by total_throughput.write
total_ops.read |
integer |
query |
False |
Filter by total_ops.read
total_ops.error.lower_bound |
integer |
query |
False |
Filter by total_ops.error.lower_bound
total_ops.error.upper_bound |
integer |
query |
False |
Filter by total_ops.error.upper_bound
total_ops.write |
integer |
query |
False |
Filter by total_ops.write
volumes.name |
string |
query |
False |
Filter by volumes.name
volumes.uuid |
string |
query |
False |
Filter by volumes.uuid
user_name |
string |
query |
False |
Filter by user_name |
svm.name |
string |
query |
False |
Filter by svm.name |
user_id |
string |
query |
False |
Filter by user_id |
iops.read |
integer |
query |
False |
Filter by iops.read |
iops.write |
integer |
query |
False |
Filter by iops.write |
iops.error.lower_bound |
integer |
query |
False |
Filter by iops.error.lower_bound |
iops.error.upper_bound |
integer |
query |
False |
Filter by iops.error.upper_bound |
integer |
query |
False |
Filter by throughput.error.lower_bound |
integer |
query |
False |
Filter by throughput.error.upper_bound |
throughput.write |
integer |
query |
False |
Filter by throughput.write |
throughput.read |
integer |
query |
False |
Filter by throughput.read |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
excluded_volumes |
List of volumes that are not included in the SVM activity tracking REST API. |
notice |
Optional field that indicates why no records are returned by the SVM activity tracking REST API. |
num_records |
integer |
Number of records. |
observation_window |
The time window over which metrics are aggregated. |
partial_response_reason |
Indicates that the metric report provides partial data. |
records |
array[top_metrics_svm_user] |
"next": {
"href": "/api/resourcelink"
"excluded_volumes": [
"reason": {
"code": "111411",
"message": "The volume is offline."
"volume": {
"name": "volume1",
"notice": {
"code": "111411207",
"num_records": 1,
"observation_window": {
"duration": 60,
"end": "2026-01-11 01:30:00 +0000",
"start": "2026-01-11 01:29:55 +0000"
"partial_response_reason": {
"code": "124518424",
"message": "The top metrics report contains partial data for read operations because NFSv4 reads using Multi-Processor I/O (MPIO) are not tracked."
"records": [
"iops": {
"error": {
"lower_bound": 34,
"upper_bound": 54
"read": 4,
"write": 8
"svm": {
"name": "svm1",
"throughput": {
"error": {
"lower_bound": 34,
"upper_bound": 54
"read": 10,
"write": 7
"total_ops": {
"error": {
"lower_bound": 34,
"upper_bound": 54
"read": 1400,
"write": 400
"total_throughput": {
"error": {
"lower_bound": 34,
"upper_bound": 54
"read": 2800,
"write": 600
"user_id": "S-1-5-21-256008430-3394229847-3930036330-1001",
"user_name": "James",
"volumes": [
"name": "volume1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
124519405 |
The activity tracking report for SVM svm.name returned zero records. Check whether the activity tracking enabled volumes belonging to the SVM have read/write traffic. Refer to the REST API documentation for more information on why there might be no records. |
124519406 |
Failed to get the activity tracking report for SVM svm.name. Reason: |
124519407 |
SVM wildcard queries are not supported for activity tracking reports. |
124519408 |
Activity tracking is not supported on SVM svm.name, because it is configured as a destination for SVM DR. |
124519409 |
Activity tracking is not supported on SVM svm.name, because it is configured as a destination of a MetroCluster SVM relationship and the SVM admin state is stopped. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
reason
code |
string |
Warning code indicating why the volume is not included in the SVM activity tracking REST API. |
message |
string |
Details why the volume is not included in the SVM activity tracking REST API. |
_links
self |
volume
_links |
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
top_metrics_svm_user_excluded_volume
List of volumes and their details as to why they are not included in the SVM activity tracking REST API.
reason |
volume |
notice
code |
string |
Warning code indicating why no records are returned. |
message |
string |
Details why no records are returned. |
observation_window
duration |
integer |
Duration of the observation window in seconds. |
end |
string |
End timestamp of the observation window in UTC. |
start |
string |
Start timestamp of the observation window in UTC. |
code |
string |
Warning code indicating why partial data was reported. |
message |
string |
A message describing the reason for partial data. |
top_metric_value_error_bounds
lower_bound |
integer |
Lower bound of the nominal value of a metric. |
upper_bound |
integer |
Upper bound of the nominal value of a metric. |
iops
error |
read |
integer |
Average number of read operations per second. |
write |
integer |
Average number of write operations per second. |
svm
_links |
name |
string |
uuid |
string |
throughput
error |
read |
integer |
Average number of read bytes received per second. |
write |
integer |
Average number of write bytes received per second. |
total_ops
error |
read |
integer |
Total read operations in the observation window. |
write |
integer |
Total write operations in the observation window. |
total_throughput
error |
read |
integer |
Total bytes read in the observation window. |
write |
integer |
Total bytes written in the observation window. |
volumes
_links |
name |
string |
uuid |
string |
Aggregated information about a user's IO activity at a SVM scope.
iops |
svm |
throughput |
total_ops |
total_throughput |
user_id |
string |
User ID of the user. |
user_name |
string |
Name of the user. |
volumes |
array[volumes] |
List of volumes where the user is generating traffic. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
