REST API reference
List users with the most I/O activity
GET /svm/svms/{svm.uuid}/top-metrics/users
Introduced In: 9.11
Retrieves a list of users with the most I/O activity.
svm.uuid
string
path
True
SVM UUID
top_metric
string
query
False
I/O activity type
  • Default value: 1
  • enum: ["iops.read", "iops.write", "throughput.read", "throughput.write"]
user_id
string
query
False
Filter by user_id
user_name
string
query
False
Filter by user_name
svm.name
string
query
False
Filter by svm.name
volumes.name
string
query
False
Filter by volumes.name
  • Introduced in: 9.12
volumes.uuid
string
query
False
Filter by volumes.uuid
iops.error.upper_bound
integer
query
False
Filter by iops.error.upper_bound
iops.error.lower_bound
integer
query
False
Filter by iops.error.lower_bound
iops.read
integer
query
False
Filter by iops.read
iops.write
integer
query
False
Filter by iops.write
throughput.error.upper_bound
integer
query
False
Filter by throughput.error.upper_bound
throughput.error.lower_bound
integer
query
False
Filter by throughput.error.lower_bound
throughput.write
integer
query
False
Filter by throughput.write
throughput.read
integer
query
False
Filter by throughput.read
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
excluded_volumes
array[top_metrics_svm_user_excluded_volume]
List of volumes that are not included in the SVM activity tracking REST API.
notice
notice
Optional field that indicates why no records are returned by the SVM activity tracking REST API.
num_records
integer
Number of records.
partial_response_reason
Indicates that the metric report provides partial data.
records
array[top_metrics_svm_user]
    "next": {
      "href": "/api/resourcelink"
  "excluded_volumes": [
      "reason": {
        "code": "111411",
        "message": "The volume is offline."
      "volume": {
        "name": "volume1",
  "notice": {
    "code": "111411207",
  "num_records": 1,
  "partial_response_reason": {
    "code": "124518424",
    "message": "The top metrics report contains partial data for read operations because NFSv4 reads using Multi-Processor I/O (MPIO) are not tracked."
  "records": [
      "iops": {
        "error": {
          "lower_bound": 34,
          "upper_bound": 54
        "read": 4,
        "write": 8
      "svm": {
        "name": "svm1",
      "throughput": {
        "error": {
          "lower_bound": 34,
          "upper_bound": 54
        "read": 10,
        "write": 7
      "user_id": "S-1-5-21-256008430-3394229847-3930036330-1001",
      "user_name": "James",
      "volumes": [
          "name": "volume1",
Status: Default
ONTAP Error Response Codes
Error Code Description
124519405
The activity tracking report for SVM svm.name returned zero records. Check whether the activity tracking enabled volumes belonging to the SVM have read/write traffic. Refer to the REST API documentation for more information on why there might be no records.
124519406
Failed to get the activity tracking report for SVM svm.name. Reason:.
124519407
SVM wildcard queries are not supported for activity tracking reports.
124519408
Activity tracking is not supported on SVM svm.name, because it is configured as a destination for SVM DR.
124519409
Activity tracking is not supported on SVM svm.name, because it is configured as a destination of a MetroCluster SVM relationship and the SVM admin state is stopped.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
reason
code
string
Warning code indicating why the volume is not included in the SVM activity tracking REST API.
message
string
Details why the volume is not included in the SVM activity tracking REST API.
self
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
List of volumes and their details as to why they are not included in the SVM activity tracking REST API.
reason
reason
volume
volume
notice
code
string
Warning code indicating why no records are returned.
message
string
Details why no records are returned.
code
string
Warning code indicating why partial data was reported.
message
string
A message describing the reason for partial data.
top_metric_value_error_bounds
lower_bound
integer
Lower bound of the nominal value of a metric.
upper_bound
integer
Upper bound of the nominal value of a metric.
iops
error
read
integer
Average number of read operations per second.
write
integer
Average number of write operations per second.
svm
_links
_links
name
string
uuid
string
throughput
error
read
integer
Average number of read bytes received per second.
write
integer
Average number of write bytes received per second.
volumes
_links
_links
name
string
uuid
string
  • Introduced in: 9.8
  • x-nullable: true
Aggregated information about a user's IO activity at a SVM scope.
iops
iops
svm
svm
throughput
throughput
user_id
string
User ID of the user.
user_name
string
Name of the user.
volumes
array[volumes]
List of volumes where the user is generating traffic.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
