Manage EMS configuration
Manage EMS configuration to collect, process, and report on events within your ONTAP environment. Use these endpoints to query observed events, customize event handling, and configure notification settings.
Overview
The Event Management System (EMS) collects and processes events, and sends notification of the events through various reporting mechanisms. The following endpoints defined under '/support/ems', allow you to query a list of observed events, and configure which events you handle and how you are notified:
/support/ems
/support/ems/events
/support/ems/messages
/support/ems/filters
/support/ems/filters/{name}/rules
/support/ems/filters/{name}/rules/{index}
/support/ems/destinations
/support/ems/destinations/{name}
Configuring an email destination
The following example configures EMS to send a support email when a WAFL event is observed with an error severity.
Configure the system-wide email parameters
# The API:
PATCH /support/ems
# The call:
curl -X PATCH "https://<mgmt-ip>/api/support/ems" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_config_patch.txt"
test_ems_config_patch.txt(body):
"mail_from": "administrator@mycompany.com",
"mail_server": "smtp@mycompany.com"
# The response:
200 OK
Configuring a filter with an enclosed rule
# The API:
POST /support/ems/filters
# The call:
curl -X POST "https://<mgmt-ip>/api/support/ems/filters" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_filters_post.txt"
test_ems_filters_post.txt(body):
"name": "critical-wafl",
"rules": [
"index": 1,
"type": "include",
"message_criteria": {
"name_pattern": "wafl.*",
"severities": "emergency,error,alert"
# The response:
201 Created
Setting up an email destination
# The API:
POST /support/ems/destinations
# The call:
curl -X POST "https://<mgmt-ip>/api/support/ems/destinations" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_dest_post.txt"
test_ems_dest_post.txt(body):
"name": "Technician_Email",
"type": "email",
"destination": "technician@mycompany.com",
"filters": [
{ "name" : "critical-wafl" }
# The response:
201 Created
