Manage EMS configuration
Configure general parameters of the Event Management System (EMS) to tailor system-wide notifications and alerts for your environment. Use these endpoints to adjust email settings and retrieve current EMS configurations.
Overview
This endpoint is used to configure general parameters of the Event Management System (EMS).
Configuring the system-wide email parameters
# The API:
PATCH /support/ems
# The call:
curl -X PATCH "https://<mgmt-ip>/api/support/ems" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_config_patch.txt"
test_ems_config_patch.txt(body):
"mail_from": "administrator@mycompany.com",
"mail_server": "smtp@mycompany.com"
# The response:
200 OK
Retrieving the EMS configuration
The following example retrieves EMS configuration for the cluster.
# The API:
GET /support/ems
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems" -H "accept: application/hal+json"
# The response:
200 OK
"mail_from": "admin@localhost",
"mail_server": "localhost",
"pubsub_enabled": true,
"href": "/api/support/ems"
