REST API reference
Manage EMS configuration
Configure general parameters of the Event Management System (EMS) to tailor alerting and notification settings for your environment.
Overview
This endpoint is used to configure general parameters of the Event Management System (EMS).
Configuring the system-wide email parameters
# The API:
PATCH /support/ems
# The call:
curl -X PATCH "https://<mgmt-ip>/api/support/ems" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_config_patch.txt"
test_ems_config_patch.txt(body):
"mail_from": "administrator@mycompany.com",
"mail_server": "mycompany.com",
"mail_server_user": "smtp"
# The response:
200 OK
Retrieving the EMS configuration
The following example retrieves EMS configuration for the cluster.
# The API:
GET /support/ems
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems" -H "accept: application/hal+json"
# The response:
200 OK
"mail_from": "admin@localhost",
"mail_server": "localhost",
"pubsub_enabled": true,
    "href": "/api/support/ems"
