Update a group membership cache setting
Updates a group-membership cache setting to modify how group membership data is cached, ensuring efficient access and retrieval of user group information.
HTTP method and endpoint
PATCH /name-services/cache/group-membership/settings/{svm.uuid}
Introduced in
ONTAP 9.11
Important notes
svm.uuid field cannot be empty.
Returns success in case no values are provided for update.
Related ONTAP commands
vserver services name-service cache group-membership settings modify
svm.uuid |
string |
path |
True |
SVM UUID. |
Request Body
| Name | Type | Description |
enabled |
boolean |
Specifies whether or not the cache is enabled. |
svm |
ttl |
string |
Specifies Time to Live for list of group members, in ISO 8601 format. |
Example request
"svm": {
"name": "svm1",
"ttl": "PT2H30M"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
23724055 |
Internal error. Configuration for Vserver failed. Verify that the cluster is healthy, then try the command again. For further assistance, contact technical support. |
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
group_membership_settings
Group membership cache setting.
enabled |
boolean |
svm |
ttl |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
