REST API reference
Update a group membership cache setting
Updates a group membership cache setting to modify the configuration for caching group membership data. This helps in optimizing directory service lookups and improving performance in environments where group membership information is frequently accessed.
HTTP method and endpoint
PATCH /name-services/cache/group-membership/settings/{svm.uuid}
Introduced in
ONTAP 9.11
Usage notes
Updates a group-membership cache setting.
Important notes
  • svm.uuid field cannot be empty.
  • Returns success in case no values are provided for update.
  • vserver services name-service cache group-membership settings modify
svm.uuid
string
path
True
SVM UUID.
Request Body
Name Type Description
enabled
boolean
Specifies whether or not the cache is enabled.
svm
svm
ttl
string
Specifies Time to Live for list of group members, in ISO 8601 format.
Example request
  "svm": {
    "name": "svm1",
  "ttl": "PT2H30M"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
23724055
Internal error. Configuration for Vserver failed. Verify that the cluster is healthy, then try the command again. For further assistance, contact technical support.
string
svm
name
string
uuid
string
group_membership_settings
Group membership cache setting.
enabled
boolean
svm
svm
ttl
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
