Update a group membership cache setting
Updates a group membership cache setting to modify the configuration for caching group membership data. This helps in optimizing directory service lookups and improving performance in environments where group membership information is frequently accessed.
HTTP method and endpoint
PATCH /name-services/cache/group-membership/settings/{svm.uuid}
Introduced in
ONTAP 9.11
Usage notes
Updates a group-membership cache setting.
Important notes
svm.uuid field cannot be empty.
Returns success in case no values are provided for update.
Related ONTAP commands
vserver services name-service cache group-membership settings modify
svm.uuid |
string |
path |
True |
SVM UUID. |
Request Body
| Name | Type | Description |
enabled |
boolean |
Specifies whether or not the cache is enabled. |
svm |
ttl |
string |
Specifies Time to Live for list of group members, in ISO 8601 format. |
Example request
"svm": {
"name": "svm1",
"ttl": "PT2H30M"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
23724055 |
Internal error. Configuration for Vserver failed. Verify that the cluster is healthy, then try the command again. For further assistance, contact technical support. |
href |
string |
_links
svm
name |
string |
uuid |
string |
group_membership_settings
Group membership cache setting.
enabled |
boolean |
svm |
ttl |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
