Updates a global nameservice cache setting
related ontap commands
vserver services name-service cache settings modify# learn more -
doc /name-services/cache/setting](#docs-name-services-name-services_cache_setting)
PATCH /name-services/cache/setting
Introduced In: 9.11
Updates a global nameservice cache setting.
Important notes
Both the cache eviction time and remote fetch option can be modified.
Related ONTAP commands
Learn more
Request Body
| Name | Type | Description |
eviction_time_interval |
string |
Specifies the time interval, in ISO 8601 format after which a periodic cache eviction happens. Default is 4 hours. |
remote_fetch_enabled |
boolean |
Indicates whether or not a node is allowed to fetch the data from a remote node. |
Example request
"eviction_time_interval": "PT2H"
Status: 200, Ok
Status: Default, Error
href |
string |
_links
global_cache_setting
string |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
