REST API reference
Update a global name service cache setting
Updates the global name service cache setting to modify cache eviction time or change the remote fetch option.
HTTP method and endpoint
PATCH /name-services/cache/setting
Introduced in
ONTAP 9.11
Usage notes
Updates a global nameservice cache setting.
Important notes
  • Both the cache eviction time and remote fetch option can be modified.
  • vserver services name-service cache settings modify
Request Body
Name Type Description
eviction_time_interval
string
Specifies the time interval, in ISO 8601 format after which a periodic cache eviction happens. Default is 4 hours.
remote_fetch_enabled
boolean
Indicates whether or not a node is allowed to fetch the data from a remote node.
Example request
  "eviction_time_interval": "PT2H"
Status: 200, Ok
Status: Default, Error
string
global_cache_setting
string
boolean
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
