Update a global name service cache setting
PATCH /name-services/cache/setting
Introduced In: 9.11
Updates a global nameservice cache setting.
Important notes
Both the cache eviction time and remote fetch option can be modified.
Related ONTAP commands
vserver services name-service cache settings modify
Learn more
Request Body
| Name | Type | Description |
eviction_time_interval  |
string  |
Specifies the time interval, in ISO 8601 format after which a periodic cache eviction happens. Default is 4 hours.  |
remote_fetch_enabled  |
boolean  |
Indicates whether or not a node is allowed to fetch the data from a remote node.  |
Example request
  "eviction_time_interval": "PT2H"
Status: 200, Ok
Status: Default, Error
href  |
string  |
_links
global_cache_setting
string  |
boolean  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
