Update UNIX user information for a user and SVM
PATCH /name-services/unix-users/{svm.uuid}/{name}
Introduced In: 9.9
Updates UNIX user information for the specified user and SVM.
name |
string |
path |
True |
UNIX user name |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
full_name |
string |
User's full name. |
id |
integer |
UNIX user ID of the specified user. |
primary_gid |
integer |
Primary group ID to which the user belongs. |
svm |
Example request
"full_name": "string",
"skip_name_validation": null,
"svm": {
"name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
23724128 |
The specified Unix user full-name contains invalid character ':' |
23724089 |
The specified UNIX user full-name is too long. Maximum supported length is 256 characters. |
23724055 |
Internal error. Failed to modify the UNIX user for the SVM. Verify that the cluster is healthy, then try the command again. |
23724090 |
Configuring individual entries is not supported because file-only configuration is enabled. |
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
unix_user
full_name |
string |
User's full name. |
id |
integer |
primary_gid |
integer |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
