REST API reference
Update UNIX user information for a user and SVM
Updates the UNIX user information for a specific user and SVM. This operation is useful when you need to modify user attributes or manage access settings.
HTTP method and endpoint
PATCH /name-services/unix-users/{svm.uuid}/{name}
Introduced in
ONTAP 9.9
Usage notes
Updates UNIX user information for the specified user and SVM.
name
string
path
True
UNIX user name
svm.uuid
string
path
True
Request Body
Name Type Description
full_name
string
User's full name.
id
integer
UNIX user ID of the specified user.
primary_gid
integer
Primary group ID to which the user belongs.
svm
svm
Example request
  "full_name": "string",
  "skip_name_validation": null,
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
23724128
The specified Unix user full-name contains invalid character ':'
23724089
The specified UNIX user full-name is too long. Maximum supported length is 256 characters.
23724055
Internal error. Failed to modify the UNIX user for the SVM. Verify that the cluster is healthy, then try the command again.
23724090
Configuring individual entries is not supported because file-only configuration is enabled.
string
svm
name
string
The name of the SVM.
uuid
string
unix_user
full_name
string
User's full name.
id
integer
primary_gid
integer
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
