Update UNIX user information for a user and SVM
PATCH /name-services/unix-users/{svm.uuid}/{name}
Introduced In: 9.9
Updates UNIX user information for the specified user and SVM.
name  |
string  |
path  |
True  |
UNIX user name  |
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
Request Body
| Name | Type | Description |
full_name  |
string  |
User's full name.  |
id  |
integer  |
UNIX user ID of the specified user.  |
primary_gid  |
integer  |
Primary group ID to which the user belongs.  |
Example request
  "full_name": "Full User Name for user1",
  "skip_name_validation": true
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
23724128  |
The specified Unix user full-name contains invalid character ':'  |
23724089  |
The specified UNIX user full-name is too long. Maximum supported length is 256 characters.  |
23724055  |
Internal error. Failed to modify the UNIX user for the SVM. Verify that the cluster is healthy, then try the command again.  |
23724090  |
Configuring individual entries is not supported because file-only configuration is enabled.  |
href  |
string  |
_links
svm
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
unix_user
full_name  |
string  |
User's full name.  |
id  |
integer  |
primary_gid  |
integer  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
