REST API reference
Update a user account
Updates a user account by modifying its role, applications, password, or lock status. This operation is useful for managing account access and permissions within your system.
HTTP method and endpoint
PATCH /security/accounts/{owner.uuid}/{name}
Introduced in
ONTAP 9.6
Usage notes
Locks or unlocks a user account and/or updates the role, applications, and/or password for the user account.
Required parameters
  • name - Account name to be updated.
  • owner.uuid - UUID of the SVM housing the user account to be updated.
Optional parameters
  • applications - Array of one or more tuples (of application and authentication methods).
  • role - RBAC role for the user account.
  • password - Password for the user account (if the authentication method is opted as password for one or more of applications).
  • second_authentication_method - Needed for MFA and only supported for ssh application. Defaults to none if not supplied.
  • comment - Comment for the user account (e.g purpose of this account).
  • locked - Set to true/false to lock/unlock the account.
  • ldap_fastbind - Set to true/false to enable LDAP Fastbind Authentication.
  • security login create
  • security login modify
  • security login password
  • security login lock
  • security login unlock
owner.uuid
string
path
True
Account owner UUID
name
string
path
True
User account name
Request Body
Name Type Description
_links
_links
applications
array[account_application]
authentication_methods
array[string]
comment
string
Optional comment for the user account.
ldap_fastbind
boolean
Optional property that specifies the mode of authentication is LDAP Fastbind.
locked
boolean
Locked status of the account.
password
string
Password for the account. The password can contain a mix of lower and upper case alphabetic characters, digits, and special characters.
password_hash_algorithm
string
Optional property that specifies the password hash algorithm used to generate a hash of the user's password for password matching.
public_key
string
Public key for SSH.
role
role
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
ssl_ca_certificate
string
SSL certificate for the chain of certificate authorities (CA) that have signed this user's client certificate.
Example request
  "applications": [
      "application": "string",
      "authentication_methods": [
        "string"
      "second_authentication_method": "string"
    "string"
  "comment": "string",
  "password": "string",
  "password_hash_algorithm": "sha512",
  "public_key": "string",
  "role": {
    "name": "admin"
  "scope": "string",
  "ssl_ca_certificate": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1261215
The role was not found.
1261218
The user was not found.
1263343
Cannot lock user with password not set or non-password authentication method.
5636096
Cannot perform the operation for this user account since the password is not set.
5636097
The operation for user account failed since user password is not set.
5636100
Modification of a service-processor user's role to a non-admin role is not supported.
5636125
The operation not supported on AutoSupport user account which is reserved.
5636129
The role does not exist.
5636154
The second-authentication-method parameter is supported for ssh application.
5636155
The second-authentication-method parameter can be specified only if the authentication-method password or public key nsswitch.
5636156
Same value cannot be specified for the second-authentication-method and the authentication-method.
5636157
If the authentication-method is domain, the second-authentication-method cannot be specified.
5636159
For a given user and application, if the second-authentication-method is specified, only one such login entry is supported.
5636164
If the value for either the authentication-method second-authentication-method is nsswitch or password, the other parameter must differ.
5636197
LDAP fastbind combination for application and authentication method is not supported.
5636198
LDAP fastbind authentication is supported only for nsswitch.
7077896
Cannot lock the account of the last console admin user.
7077906
A role with that name has not been defined for the Vserver.
7077911
The user is not configured to use the password authentication method.
7077918
The password cannot contain the username.
7077919
The minimum length for new password does not meet the policy.
7077920
The new password must have both letters and numbers.
7077921
The minimum number of special characters required do not meet the policy.
7077924
The new password must be different than last N passwords.
7077925
The new password must be different to the old password.
7077929
7077940
The password exceeds maximum supported length.
7077941
Defined password composition exceeds the maximum password length of 128 characters.
7078900
An aAdmin password is not set. Set the password by including it in the request.
string
account_application
application
string
Applications
array[string]
string
An optional additional authentication method for MFA. This only works with SSH as the application. It is ignored for all other applications.
owner
Owner name and UUID that uniquely identifies the user account.
_links
_links
name
string
The name of the SVM.
uuid
string
role
_links
_links
name
string
Role name
account
_links
_links
applications
array[string]
comment
string
ldap_fastbind
boolean
locked
boolean
password
string
string
public_key
string
Public key for SSH.
role
role
scope
string
ssl_ca_certificate
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
