Update a user account
Updates a user account by modifying its settings, such as locking or unlocking the account, changing the role, applications, or password associated with it. You typically use this endpoint when managing user access and roles within your system.
HTTP method and endpoint
PATCH /security/accounts/{owner.uuid}/{name}
Introduced in
ONTAP 9.6
Usage notes
Locks or unlocks a user account and/or updates the role, applications, and/or password for the user account.
Required parameters
name- Account name to be updated. -
owner.uuid- UUID of the SVM housing the user account to be updated.
Optional parameters
applications- Array of one or more tuples (of application and authentication methods). -
role- RBAC role for the user account. -
password- Password for the user account (if the authentication method is opted as password for one or more of applications). -
second_authentication_method- Needed for MFA and only supported for ssh application. Defaults tononeif not supplied. -
comment- Comment for the user account (e.g purpose of this account). -
locked- Set to true/false to lock/unlock the account. -
ldap_fastbind- Set to true/false to enable LDAP Fastbind Authentication.
Related ONTAP commands
security login create -
security login modify -
security login password -
security login lock -
security login unlock
owner.uuid |
string |
path |
True |
Account owner UUID |
name |
string |
path |
True |
User account name |
Request Body
| Name | Type | Description |
_links |
applications |
array[account_application] |
comment |
string |
Optional comment for the user account. |
ldap_fastbind |
boolean |
Optional property that specifies the mode of authentication is LDAP Fastbind. |
locked |
boolean |
Locked status of the account. |
password |
string |
Password for the account. The password can contain a mix of lower and upper case alphabetic characters, digits, and special characters. |
password_hash_algorithm |
string |
Optional property that specifies the password hash algorithm used to generate a hash of the user's password for password matching. |
role |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
Example request
"applications": [
"application": "string",
"authentication_methods": [
"string"
"second_authentication_method": "string"
"comment": "string",
"password": "string",
"password_hash_algorithm": "sha512",
"role": {
"name": "admin"
"scope": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1261215 |
The role was not found. |
1261218 |
The user was not found. |
1263343 |
Cannot lock user with password not set or non-password authentication method. |
5636096 |
Cannot perform the operation for this user account since the password is not set. |
5636097 |
The operation for user account failed since user password is not set. |
5636100 |
Modification of a service-processor user's role to a non-admin role is not supported. |
5636125 |
The operation not supported on AutoSupport user account which is reserved. |
5636129 |
The role does not exist. |
5636154 |
The second-authentication-method parameter is supported for ssh application. |
5636155 |
The second-authentication-method parameter can be specified only if the authentication-method password or public key nsswitch. |
5636156 |
Same value cannot be specified for the second-authentication-method and the authentication-method. |
5636157 |
If the authentication-method is domain, the second-authentication-method cannot be specified. |
5636159 |
For a given user and application, if the second-authentication-method is specified, only one such login entry is supported. |
5636164 |
If the value for either the authentication-method second-authentication-method is nsswitch or password, the other parameter must differ. |
5636197 |
LDAP fastbind combination for application and authentication method is not supported. |
5636198 |
LDAP fastbind authentication is supported only for nsswitch. |
7077896 |
Cannot lock the account of the last console admin user. |
7077906 |
A role with that name has not been defined for the Vserver. |
7077911 |
The user is not configured to use the password authentication method. |
7077918 |
The password cannot contain the username. |
7077919 |
The minimum length for new password does not meet the policy. |
7077920 |
The new password must have both letters and numbers. |
7077921 |
The minimum number of special characters required do not meet the policy. |
7077924 |
The new password must be different than last N passwords. |
7077925 |
The new password must be different to the old password. |
7077929 |
7077940 |
The password exceeds maximum supported length. |
7077941 |
Defined password composition exceeds the maximum password length of 128 characters. |
7078900 |
An aAdmin password is not set. Set the password by including it in the request. |
href |
string |
_links
account_application
application |
string |
Applications |
authentication_methods |
array[string] |
second_authentication_method |
string |
An optional additional authentication method for MFA. This only works with SSH as the application. It is ignored for all other applications. |
owner
Owner name and UUID that uniquely identifies the user account.
_links |
name |
string |
The name of the SVM. |
uuid |
string |
role
_links |
name |
string |
Role name |
account
_links |
applications |
comment |
string |
ldap_fastbind |
boolean |
locked |
boolean |
password |
string |
string |
role |
scope |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
