Update a user account
Updates a user account by locking or unlocking it, or modifying its role, applications, and password. This endpoint is useful when managing account access and permissions within your storage environment.
HTTP method and endpoint
PATCH /security/accounts/{owner.uuid}/{name}
Introduced in
ONTAP 9.6
Usage notes
Locks or unlocks a user account and/or updates the role, applications, and/or password for the user account.
Required parameters
name- Account name to be updated. -
owner.uuid- UUID of the SVM housing the user account to be updated.
Optional parameters
applications- Array of one or more tuples (of application and authentication methods). -
role- RBAC role for the user account. -
password- Password for the user account (if the authentication method is opted as password for one or more of applications). -
second_authentication_method- Needed for MFA and only supported for ssh and service_processor applications. Defaults to none if not supplied. -
comment- Comment for the user account (e.g purpose of this account). -
locked- Set to true/false to lock/unlock the account. -
is_ldap_fastbind- Set to true/false to enable LDAP Fastbind Authentication. -
is_ns_switch_group- Set to true/false to specify whether the user is an LDAP or NIS group.
Related ONTAP commands
security login create -
security login modify -
security login password -
security login lock -
security login unlock
owner.uuid |
string |
path |
True |
Account owner UUID |
name |
string |
path |
True |
User account name |
Request Body
| Name | Type | Description |
applications |
array[account_application] |
comment |
string |
Optional comment for the user account. |
locked |
boolean |
Locked status of the account. |
password |
string |
Password for the account. The password can contain a mix of lower and upper case alphabetic characters, digits, and special characters. |
password_hash_algorithm |
string |
Password hash algorithm used to generate a hash of the user's password for password matching.To modify "password_hash_algorithm", use REST API "/api/security/authentication/password". |
role |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
Example request
"applications": [
"application": "string",
"authentication_methods": [
"string"
"second_authentication_method": "string"
"comment": "string",
"password": "string",
"password_hash_algorithm": "sha512",
"role": {
"name": "admin"
"scope": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1261215 |
The role was not found. |
1261218 |
The user was not found. |
1263343 |
Cannot lock user with password not set or non-password authentication method. |
5636096 |
Cannot perform the operation for this user account since the password is not set. |
5636097 |
The operation for user account failed since user password is not set. |
5636100 |
Modification of a service-processor user's role to a non-admin role is not supported. |
5636125 |
The operation not supported on AutoSupport user account which is reserved. |
5636129 |
The role does not exist. |
5636136 |
Specifying "is_ns_switch_group" as "true" is supported only for authentication method "nsswitch". |
5636154 |
The second authentication method parameter is supported for SSH and Service Processor (SP) applications only. |
5636155 |
The second-authentication-method parameter can be specified only if the authentication-method password or public key nsswitch. |
5636156 |
Same value cannot be specified for the second-authentication-method and the authentication-method. |
5636159 |
For a given user and application, if the second-authentication-method is specified, only one such login entry is supported. |
5636164 |
If the value for either the authentication-method second-authentication-method is nsswitch or password, the other parameter must differ. |
5636165 |
Second authentication method is not supported for NIS or LDAP group based accounts. |
5636197 |
LDAP fastbind combination for application and authentication method is not supported. |
5636198 |
LDAP fastbind authentication is supported only for nsswitch. |
5636210 |
User creation failed because LDAP is not configured for the SVM or the LDAP connection is not secure. |
5636212 |
TOTP is supported only when the primary authentication method is password or public key. |
5636214 |
Configuring the user with TOTP as secondary authentication method requires an effective cluster version of 9.13.1 or later |
5636223 |
Specifying "is_ns_switch_group" as "true" is supported only for SSH, ONTAPI and HTTP applications. |
5636224 |
Configuring a Service Processor (SP) user with two-factor authentication requires an effective cluster version of 9.15.1 or later. |
5636225 |
For a Service Processor (SP) user, the second factor of authentication must be one of publickey or none. |
5636226 |
Internal error. Failed to check for ONTAP capability. |
7077896 |
Cannot lock the account of the last console admin user. |
7077906 |
A role with that name has not been defined for the Vserver. |
7077911 |
The user is not configured to use the password authentication method. |
7077918 |
The password cannot contain the username. |
7077919 |
The minimum length for new password does not meet the policy. |
7077920 |
The new password must have both letters and numbers. |
7077921 |
The minimum number of special characters required do not meet the policy. |
7077924 |
The new password must be different than last N passwords. |
7077925 |
The new password must be different to the old password. |
7077929 |
7077940 |
The password exceeds maximum supported length. |
7077941 |
Defined password composition exceeds the maximum password length of 128 characters. |
7078900 |
An aAdmin password is not set. Set the password by including it in the request. |
href |
string |
_links
account_application
application |
string |
Applications |
authentication_methods |
array[string] |
is_ldap_fastbind |
boolean |
Optional property that specifies the mode of authentication as LDAP Fastbind. |
is_ns_switch_group |
boolean |
Optional property that specifies whether the user is an LDAP or NIS group. |
second_authentication_method |
string |
An optional additional authentication method for multifactor authentication (MFA). This property is only supported for SSH (ssh) and Service Processor (service_processor) applications. It is ignored for all other applications. Time-based One-Time Passwords (TOTPs) are only supported with the authentication method password or public key. For the Service Processor (service_processor) application, none and publickey are the only supported enum values. |
owner
Owner name and UUID that uniquely identifies the user account.
name |
string |
uuid |
string |
role
name |
string |
Role name |
account
applications |
comment |
string |
locked |
boolean |
password |
string |
string |
role |
scope |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
