REST API reference
Updates a multi-admin-verify approval group
PATCH /security/multi-admin-verify/approval-groups/{owner.uuid}/{name}
Introduced In: 9.11
Updates a multi-admin-verify approval group.
owner.uuid
string
path
True
name
string
path
True
Request Body
Name Type Description
approvers
array[string]
List of users that can approve a request.
email
array[string]
Email addresses that are notified when a request is created, approved, vetoed, or executed.
Example request
  "approvers": [
    "string"
  "email": [
    "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
262331
At least one approver is required.
262332
An add or remove list is required.
string
owner
The owner of the approval group. The only valid owner is currently the cluster.
name
string
The name of the SVM.
uuid
string
multi_admin_verify_approval_group
approvers
array[string]
email
array[string]
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
