Update a multi-admin-verify approval group
Updates a multi-admin-verify approval group to modify its settings or configuration. This is useful when you need to adjust approval criteria to align with new security policies or administrative requirements.
HTTP method and endpoint
PATCH /security/multi-admin-verify/approval-groups/{owner.uuid}/{name}
Introduced in
ONTAP 9.11
owner.uuid |
string |
path |
True |
name |
string |
path |
True |
Request Body
| Name | Type | Description |
approvers |
array[string] |
List of users that can approve a request. |
array[string] |
Email addresses that are notified when a request is created, approved, vetoed, or executed. |
Example request
"approvers": [
"string"
"email": [
"string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262331 |
At least one approver is required. |
262332 |
An add or remove list is required. |
href |
string |
_links
owner
The owner of the approval group. The only valid owner is currently the cluster.
name |
string |
uuid |
string |
multi_admin_verify_approval_group
approvers |
array[string] |
array[string] |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
