Update a multi-admin-verify approval group
Updates a multi-admin-verify approval group, modifying its settings as needed to align with your administrative requirements.
HTTP method and endpoint
PATCH /security/multi-admin-verify/approval-groups/{owner.uuid}/{name}
Introduced in
ONTAP 9.11
owner.uuid |
string |
path |
True |
name |
string |
path |
True |
Request Body
| Name | Type | Description |
approvers |
array[string] |
List of users that can approve a request. |
array[string] |
Email addresses that are notified when a request is created, approved, vetoed, or executed. |
owner |
The owner of the approval group. The only valid owner is currently the cluster. |
Example request
"approvers": [
"string"
"email": [
"string"
"owner": {
"name": "svm1"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262331 |
At least one approver is required. |
262332 |
An add or remove list is required. |
262333 |
Invalid user in approval group. |
href |
string |
_links
owner
name |
string |
The name of the SVM. This field cannot be specified in a POST or PATCH method. |
multi_admin_verify_approval_group
approvers |
array[string] |
array[string] |
owner |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
