Updates a multi-admin-verify rule
PATCH /security/multi-admin-verify/rules/{owner.uuid}/{operation}
Introduced In: 9.11
Updates a multi-admin-verify rule.
owner.uuid |
string |
path |
True |
operation |
string |
path |
True |
Request Body
| Name | Type | Description |
approval_expiry |
string |
Time for requests to be approved, in ISO-8601 duration format. If not set, the global setting is used. |
approval_groups |
array[approval_groups] |
List of approval groups that are allowed to approve requests for rules that don't have approval groups. |
auto_request_create |
boolean |
When true, ONTAP automatically creates a request for any failed operation where there is no matching pending request.
create_time |
string |
execution_expiry |
string |
Time for requests to be executed once approved, in ISO-8601 duration format. If not set, the global setting is used. |
query |
string |
When specified, this property limits the entries that require approvals to those that match the specified query. |
required_approvers |
integer |
The number of required approvers, excluding the user that made the request. |
system_defined |
boolean |
Specifies whether the rule is system-defined or user-defined. |
Example request
"approval_expiry": "string",
"approval_groups": [
"name": "string"
"create_time": "string",
"execution_expiry": "string",
"query": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262310 |
System rules cannot be deleted or have their query modified. |
262311 |
Value must be greater than zero. |
262312 |
Number of required approvers must be less than the total number of unique approvers in the approval-groups. |
262313 |
Number of unique approvers in the approval-groups must be greater than the number of required approvers. |
262316 |
Value must be in the range one second to two weeks. |
approval_groups
name |
string |
Name of the approval group. |
href |
string |
_links
owner
The owner of the rule. The only valid owner is currently the cluster.
name |
string |
The name of the SVM. |
uuid |
string |
multi_admin_verify_rule
approval_expiry |
string |
approval_groups |
boolean |
create_time |
string |
execution_expiry |
string |
query |
string |
integer |
system_defined |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
