REST API reference
Update a multi-admin-verify rule
PATCH /security/multi-admin-verify/rules/{owner.uuid}/{operation}
Introduced In: 9.11
Updates a multi-admin-verify rule.
owner.uuid
string
path
True
operation
string
path
True
Request Body
Name Type Description
approval_expiry
string
Time for requests to be approved, in ISO-8601 duration format. If not set, the global setting is used.
approval_groups
array[approval_groups]
List of approval groups that are allowed to approve requests for rules that don't have approval groups.
auto_request_create
boolean
When true, ONTAP automatically creates a request for any failed operation where there is no matching pending request.
  • Default value: 1
  • Introduced in: 9.11
  • x-nullable: true
create_time
string
execution_expiry
string
Time for requests to be executed once approved, in ISO-8601 duration format. If not set, the global setting is used.
owner
owner
The owner of the rule. The only valid owner is currently the cluster.
query
string
When specified, this property limits the entries that require approvals to those that match the specified query.
required_approvers
integer
The number of required approvers, excluding the user that made the request.
system_defined
boolean
Specifies whether the rule is system-defined or user-defined.
Example request
  "approval_expiry": "string",
  "approval_groups": [
      "name": "string"
  "create_time": "string",
  "execution_expiry": "string",
  "owner": {
    "name": "svm1"
  "query": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
262310
System rules cannot be deleted or have their query modified.
262311
Value must be greater than zero.
262312
Number of required approvers must be less than the total number of unique approvers in the approval-groups.
262313
Number of unique approvers in the approval-groups must be greater than the number of required approvers.
262316
Value must be in the range two minutes to two weeks.
approval_groups
name
string
Name of the approval group.
string
owner
name
string
The name of the SVM. This field cannot be specified in a POST or PATCH method.
multi_admin_verify_rule
approval_expiry
string
approval_groups
auto_request_create
boolean
  • Default value: 1
  • x-nullable: true
create_time
string
execution_expiry
string
owner
owner
query
string
required_approvers
integer
system_defined
boolean
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
