Update a multi-admin-verify rule
PATCH /security/multi-admin-verify/rules/{owner.uuid}/{operation}
Introduced In: 9.11
Updates a multi-admin-verify rule.
owner.uuid  |
string  |
path  |
True  |
operation  |
string  |
path  |
True  |
Request Body
| Name | Type | Description |
approval_expiry  |
string  |
Time for requests to be approved, in ISO-8601 duration format. If not set, the global setting is used.  |
approval_groups  |
array[approval_groups]  |
List of approval groups that are allowed to approve requests for rules that don't have approval groups.  |
auto_request_create  |
boolean  |
When true, ONTAP automatically creates a request for any failed operation where there is no matching pending request.
create_time  |
string  |
execution_expiry  |
string  |
Time for requests to be executed once approved, in ISO-8601 duration format. If not set, the global setting is used.  |
owner  |
The owner of the rule. The only valid owner is currently the cluster.  |
query  |
string  |
When specified, this property limits the entries that require approvals to those that match the specified query.  |
required_approvers  |
integer  |
The number of required approvers, excluding the user that made the request.  |
system_defined  |
boolean  |
Specifies whether the rule is system-defined or user-defined.  |
Example request
  "approval_expiry": "string",
  "approval_groups": [
      "name": "string"
  "create_time": "string",
  "execution_expiry": "string",
  "owner": {
    "name": "svm1"
  "query": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262310  |
System rules cannot be deleted or have their query modified.  |
262311  |
Value must be greater than zero.  |
262312  |
Number of required approvers must be less than the total number of unique approvers in the approval-groups.  |
262313  |
Number of unique approvers in the approval-groups must be greater than the number of required approvers.  |
262316  |
Value must be in the range one second to two weeks.  |
approval_groups
name  |
string  |
Name of the approval group.  |
href  |
string  |
_links
owner
name  |
string  |
The name of the SVM. This field cannot be specified in a POST or PATCH method.  |
multi_admin_verify_rule
approval_expiry  |
string  |
approval_groups  |
boolean  |
create_time  |
string  |
execution_expiry  |
string  |
owner  |
query  |
string  |
integer  |
system_defined  |
boolean  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
