Update an event destination
Updates an event destination to reflect new filter configurations or certificate parameters, aligning the destination with your current notification requirements.
HTTP method and endpoint
PATCH /support/ems/destinations/{name}
Introduced in
ONTAP 9.6
Recommended optional properties
filters.name- New list of filters that should direct to this destination. The existing list is discarded. -
certificate- New certificate parameters when the destination type isrest api.
Related ONTAP commands
event notification destination modify -
event notification modify
name |
string |
path |
True |
Destination name |
Request Body
| Name | Type | Description |
certificate |
Security certificate object reference |
connectivity |
destination |
string |
Event destination |
filters |
array[filters] |
system_defined |
boolean |
Flag indicating system-defined destinations. |
Example request
"certificate": {
"ca": "VeriSign",
"name": "cert1",
"serial_number": "1234567890"
"connectivity": {
"errors": [
"message": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"message": "entry doesn't exist"
"node": {
"name": "node1",
"state": "fail"
"destination": "administrator@mycompany.com",
"filters": [
"name": "important-events"
"system_defined": 1
Status: 200, Ok
certificate |
connectivity |
destination |
string |
Event destination |
filters |
array[filters] |
system_defined |
boolean |
"certificate": {
"ca": "VeriSign",
"name": "cert1",
"connectivity": {
"errors": [
"message": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"node": {
"name": "node1",
"state": "fail"
"filters": [
"system_defined": 1
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983088 |
The destination name provided cannot be empty |
983089 |
The destination name provided cannot contain spaces |
983094 |
The destination name provided is invalid. The destination name must contain between 2 and 64 characters and start and end with an alphanumeric symbol or _(underscore). The allowed special characters are _(underscore) and -(hyphen) |
983104 |
The syslog destination provided is invalid |
983116 |
The number of notifications has reached maximum capacity |
983117 |
The number of destinations has reached maximum capacity |
983129 |
The rest-api destination must contain a valid scheme, such as http// or https// |
983130 |
The rest-api destination provided contains an invalid URL |
983131 |
The rest-api destination provided contains an invalid IPv6 URL |
983142 |
The security certificate provided does not exist |
983143 |
The private security key provided does not exist |
983144 |
The security certificate information provided is incomplete. Provide the certificate and serial number |
983145 |
The rest-api destination provided has an 'http://' scheme. It is invalid to provide certificate information |
983150 |
The type of an existing destination cannot be changed |
983151 |
A property provided cannot be configured on the requested destination type |
983152 |
Default destinations cannot be modified or removed |
href |
string |
_links
certificate
_links |
ca |
string |
Client certificate issuing CA |
name |
string |
Certificate name |
serial_number |
string |
Client certificate serial number |
arguments
code |
string |
Argument code |
message |
string |
Message argument |
message
Information to be displayed to the user.
arguments |
array[arguments] |
Message arguments |
code |
string |
Unique message code. |
message |
string |
User message. |
node
name |
string |
uuid |
string |
errors
Error object included in the event of connectivity failure.
message |
Information to be displayed to the user. |
node |
connectivity
errors |
array[errors] |
A list of errors encountered during connectivity checks. |
state |
string |
Current connectivity state. |
filters
name |
string |
ems_destination
certificate |
connectivity |
destination |
string |
Event destination |
filters |
array[filters] |
system_defined |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
