REST API reference
Updates an event destination
  • certificate - new certificate parameters when the destination type is rest api # related ontap commands
  • event notification destination modify
  • event notification modify
PATCH /support/ems/destinations/{name}
Introduced In: 9.6
Updates an event destination.
  • filters.name - New list of filters that should direct to this destination. The existing list is discarded.
  • certificate - New certificate parameters when the destination type is rest api.
name
string
path
True
Destination name
Request Body
Name Type Description
certificate
certificate
Certificate information is valid for the "rest_api" type.
destination
string
Event destination
filters
array[filters]
Example request
  "certificate": {
    "ca": "VeriSign",
    "serial_number": "1234567890"
  "destination": "administrator@mycompany.com",
  "filters": [
      "name": "important-events"
Status: 200, Ok
certificate
certificate
destination
string
Event destination
filters
array[filters]
  "certificate": {
    "ca": "VeriSign",
  "filters": [
Status: Default
ONTAP Error Response Codes
Error Code Description
983088
The destination name provided cannot be empty
983089
The destination name provided cannot contain spaces
983094
The destination name provided is invalid. The destination name must contain between 2 and 64 characters and start and end with an alphanumeric symbol or _(underscore). The allowed special characters are _(underscore) and -(hyphen)
983104
The syslog destination provided is invalid
983116
The number of notifications has reached maximum capacity
983117
The number of destinations has reached maximum capacity
983129
The rest-api destination must contain a valid scheme, such as http// or https//
983130
The rest-api destination provided contains an invalid URL
983131
The rest-api destination provided contains an invalid IPv6 URL
983142
The security certificate provided does not exist
983143
The private security key provided does not exist
983144
The security certificate information provided is incomplete. Provide the certificate and serial number
983145
The rest-api destination provided has an 'http://' scheme. It is invalid to provide certificate information
983150
The type of an existing destination cannot be changed
983151
A property provided cannot be configured on the requested destination type
983152
Default destinations cannot be modified or removed
string
certificate
ca
string
Client certificate issuing CA
serial_number
string
Client certificate serial number
filters
name
string
ems_destination
certificate
certificate
destination
string
Event destination
filters
array[filters]
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
