REST API reference
Update an event destination
Updates an event destination to modify its configuration, such as the list of filters or certificate parameters, ensuring it meets the requirements for your notification setup.
HTTP method and endpoint
PATCH /support/ems/destinations/{name}
Introduced in
ONTAP 9.6
  • filters.name - New list of filters that should direct to this destination. The existing list is discarded.
  • certificate - New certificate parameters when the destination type is rest api.
  • event notification destination modify
  • event notification modify
name
string
path
True
Destination name
Request Body
Name Type Description
certificate
certificate
Specifies the client-side certificate used by the ONTAP system when mutual authentication is required. This object is only applicable for rest_api type destinations. Both the ca and serial_number fields must be specified when configuring a certificate in a PATCH or POST request. The name field is read-only and cannot be used to configure a client-side certificate.
  • Introduced in: 9.6
connectivity
connectivity
destination
string
Event destination
filters
array[filters]
syslog
syslog
system_defined
boolean
Flag indicating system-defined destinations.
Example request
  "certificate": {
    "ca": "VeriSign",
    "name": "cert1",
    "serial_number": 1234567890
  "connectivity": {
    "errors": [
        "message": {
          "arguments": [
              "code": "string",
              "message": "string"
          "code": "4",
          "message": "entry doesn't exist"
        "node": {
          "name": "node1",
    "state": "fail"
  "destination": "administrator@mycompany.com",
  "filters": [
      "name": "important-events"
  "syslog": {
    "format": {
      "hostname_override": "string",
      "message": "string",
      "timestamp_override": "string"
    "port": 514,
    "transport": "string"
  "system_defined": 1
Status: 200, Ok
certificate
certificate
connectivity
connectivity
destination
string
Event destination
filters
array[filters]
syslog
syslog
system_defined
boolean
  "certificate": {
    "ca": "VeriSign",
    "name": "cert1",
  "connectivity": {
    "errors": [
        "message": {
          "arguments": [
              "code": "string",
              "message": "string"
          "code": "4",
        "node": {
          "name": "node1",
    "state": "fail"
  "filters": [
  "syslog": {
    "format": {
    "port": 514,
  "system_defined": 1
Status: Default
ONTAP Error Response Codes
Error Code Description
983088
The destination name provided cannot be empty
983089
The destination name provided cannot contain spaces
983094
The destination name provided is invalid. The destination name must contain between 2 and 64 characters and start and end with an alphanumeric symbol or _(underscore). The allowed special characters are _(underscore) and -(hyphen)
983104
The syslog destination provided is invalid
983107
A provided filter does not exist
983116
The number of notifications has reached maximum capacity
983117
The number of destinations has reached maximum capacity
983129
The rest-api destination must contain a valid scheme, such as http// or https//
983130
The rest-api destination provided contains an invalid URL
983131
The rest-api destination provided contains an invalid IPv6 URL
983142
The security certificate provided does not exist
983143
The private security key provided does not exist
983144
The security certificate information provided is incomplete. Provide the certificate and serial number
983145
The rest-api destination provided has an 'http://' scheme. It is invalid to provide certificate information
983150
The type of an existing destination cannot be changed
983152
Default destinations cannot be modified or removed
983184
A provided property cannot be configured on the requested destination type
983200
Access control role compatibility issue with provided filters
string
access_control_role
Indicates the access control role that created the event destination and is used to control access to the destination based on role-based access control (RBAC) rules. If created by the 'admin' user, the field is unset.
_links
_links
name
string
Role name
certificate
_links
_links
ca
string
Client certificate issuing CA
name
string
Certificate name
serial_number
string
Client certificate serial number
arguments
code
string
Argument code
message
string
Message argument
message
arguments
array[arguments]
Message arguments
code
string
Unique message code.
message
string
User message.
node
name
string
uuid
string
errors
Error object included in the event of connectivity failure.
message
message
node
node
connectivity
errors
array[errors]
A list of errors encountered during connectivity checks.
state
string
Current connectivity state.
filters
name
string
format
hostname_override
string
Syslog Hostname Format Override. The supported hostname formats are no_override (hostname format based on the syslog.format.message property i.e. fqdn if syslog.format.message is rfc_5424, hostname_only if syslog.format.message is legacy_netapp), fqdn (Fully Qualified Domain Name) and hostname_only.
message
string
Syslog Message Format. The supported message formats are legacy_netapp (format: <PRIVAL>TIMESTAMP [HOSTNAME:Event-name:Event-severity]: MSG) and rfc_5424 (format: <PRIVAL>VERSION TIMESTAMP HOSTNAME Event-source - Event-name - MSG).
timestamp_override
string
Syslog Timestamp Format Override. The supported timestamp formats are no_override (timestamp format based on the syslog.format.message property i.e. rfc_3164 if syslog.format.message is legacy_netapp, iso_8601_local_time if syslog.format.message is rfc_5424), rfc_3164 (format: Mmm dd hh:mm:ss), iso_8601_local_time (format: YYYY-MM-DDThh:mm:ss+/-hh:mm) and iso_8601_utc (format: YYYY-MM-DDThh:mm:ssZ).
syslog
format
format
port
integer
Syslog Port.
transport
string
Syslog Transport Protocol.
ems_destination
certificate
certificate
connectivity
connectivity
destination
string
Event destination
filters
array[filters]
syslog
syslog
system_defined
boolean
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
