Upload a software or firmware package located on the local file system
Uploads a software or firmware package from your local file system. This can be useful for updating or installing new software components on your ONTAP system.
HTTP method and endpoint
POST /cluster/software/upload
Introduced in
ONTAP 9.8
Usage notes
Uploads a software or firmware package located on the local filesystem.
Related ONTAP commands
cluster image package get
Learn more
file |
file |
formData |
False |
Info specification |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"uuid": "string"
Status: Default, Error
href |
string |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
