Upload a software or firmware package located on the local file system
Uploads a software or firmware package from the local file system to update or install new software components on your system.
HTTP method and endpoint
POST /cluster/software/upload
Introduced in
ONTAP 9.8
Usage notes
Uploads a software or firmware package located on the local filesystem.
Related ONTAP commands
cluster image package get
Learn more
file |
file |
formData |
False |
Info specification |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"uuid": "string"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
10551359 |
Internal error. Failed to process the package after download completed. Try uploading the file again or contact technical support for assistance. |
10551373 |
Operation took longer than the maximum 1 hour time limit. |
10551391 |
Internal error. Contact technical support for assistance. |
10551392 |
10551496 |
Firmware file already exists. |
10551797 |
Internal error. Failed to check if file upload is enabled. |
10551798 |
File upload is disabled. Enable file upload by setting "ApacheUploadEnabled 1" in the web services configuration file or contact technical support for assistance. |
10551799 |
The requested filename exceeds the max path length. Rename using a shorter name. |
10551800 |
Internal error. Access permissions restrict file upload. This is likely due to a bad web jail setup. Contact technical support for assistance. |
10551801 |
Internal error. A read/write error occurred when uploading this file. Contact technical support for assistance |
10551802 |
An invalid argument was supplied to create a file handle. Try uploading the file again or contact technical support for assistance. |
10551803 |
An unknown error occurred. Retry file upload operation again or contact technical support for assistance. |
10551804 |
Internal error. There is not sufficient space in the file upload directory to upload this file. Contact technical support for assistance. |
10551805 |
Internal error in JAIL setup. Contact technical support for assistance. |
10551806 |
Internal error. Failed to write to file in the webjail directory. Contact technical support for assistance. |
10551807 |
The request must only contain a single file. More than one file per request is not supported. |
10551808 |
The request must be of type multipart/form-data. |
10551892 |
Package upload failed due to an unhealthy node. Restore the node to a healthy state, then retry the operation. |
href |
string |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
