REST API reference
Upload a software or firmware package located on the local file system
Uploads a software or firmware package from the local file system to update or install new software components on your system.
HTTP method and endpoint
POST /cluster/software/upload
Introduced in
ONTAP 9.8
Usage notes
Uploads a software or firmware package located on the local filesystem.
  • cluster image package get
file
file
formData
False
Info specification
return_records
boolean
query
False
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
    "uuid": "string"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
10551359
Internal error. Failed to process the package after download completed. Try uploading the file again or contact technical support for assistance.
10551373
Operation took longer than the maximum 1 hour time limit.
10551391
Internal error. Contact technical support for assistance.
10551392
10551496
Firmware file already exists.
10551797
Internal error. Failed to check if file upload is enabled.
10551798
File upload is disabled. Enable file upload by setting "ApacheUploadEnabled 1" in the web services configuration file or contact technical support for assistance.
10551799
The requested filename exceeds the max path length. Rename using a shorter name.
10551800
Internal error. Access permissions restrict file upload. This is likely due to a bad web jail setup. Contact technical support for assistance.
10551801
Internal error. A read/write error occurred when uploading this file. Contact technical support for assistance
10551802
An invalid argument was supplied to create a file handle. Try uploading the file again or contact technical support for assistance.
10551803
An unknown error occurred. Retry file upload operation again or contact technical support for assistance.
10551804
Internal error. There is not sufficient space in the file upload directory to upload this file. Contact technical support for assistance.
10551805
Internal error in JAIL setup. Contact technical support for assistance.
10551806
Internal error. Failed to write to file in the webjail directory. Contact technical support for assistance.
10551807
The request must only contain a single file. More than one file per request is not supported.
10551808
The request must be of type multipart/form-data.
10551892
Package upload failed due to an unhealthy node. Restore the node to a healthy state, then retry the operation.
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
