Create a new broadcast domain
Creates a new broadcast domain to define a network layer for communication within your ONTAP environment. Use this operation to specify network characteristics like the maximum transmission unit and associate the domain with an IPspace.
HTTP method and endpoint
POST /network/ethernet/broadcast-domains
Introduced in
ONTAP 9.6
Required properties
name- Name of the broadcast-domain to create. -
mtu- Maximum transmission unit (MTU) of the broadcast domain.
Recommended optional properties
ipspace.nameoripspace.uuid- IPspace the broadcast domain belongs to.
Default property values
If not specified in POST, the following default property values are assigned:
ipspace- Default
Related ONTAP commands
network port broadcast-domain create
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
_links |
ipspace |
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input. |
mtu |
integer |
Maximum transmission unit, largest packet size on this network |
name |
string |
Name of the broadcast domain, scoped to its IPspace |
ports |
array[ports] |
Ports that belong to the broadcast domain |
uuid |
string |
Broadcast domain UUID |
Example request
"ipspace": {
"name": "exchange",
"mtu": 1500,
"name": "bd1",
"ports": [
"name": "e1b",
"node": {
"name": "node1"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1377267 |
The specified IPspace does not exist. |
1967082 |
The specified ipspace.name does not match the IPspace name of ipspace.uuid. |
1967102 |
A POST operation might have left the configuration in an inconsistent state. Check the configuration. |
53281982 |
The specified broadcast domain name is reserved by the system. |
href |
string |
_links
ipspace
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
node
name |
string |
Name of node on which the port is located. |
ports
Port UUID along with readable names
_links |
name |
string |
node |
uuid |
string |
broadcast_domain
Set of ports that will receive a broadcast Ethernet packet from any of them
_links |
ipspace |
mtu |
integer |
name |
string |
ports |
array[ports] |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
